Question about Dynex Wireless-G USB 2.0 Network Adapter
Can't access internet explorer ip address for Dynex Router
I have to switch the ip address to be able to setup my Dynex G router. When I type in the ip address 192.168.2.1 the internet explorer page says that it can't be opened. I know that I have to change the ip address to 192.168.3.1 and I've checked my firewall/virus protection to see if its blocking it and its not. I've call customer services and they keep telling me to return it and get a new one, I want to know why the Dyex setup will not open up? Frustrated!!!
  • schaulsj Jan 25, 2009
    I tried both routes and neither one works, internet explorer still says page cannot be opened. Yet when I plug the ethernet cord directly to my computer it allows me in the modem's ip address.
  • 4 Answers
First things first.. if the router is connected hardwired, open command prompt and type 'ipconfig' and than enter, you will get some thing like this
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Vishal>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
        Connection-specific DNS Suffix  . :         IP Address. . . . . . . . . . . . : 123.237.89.224         Subnet Mask . . . . . . . . . . . : 255.255.255.0         Default Gateway . . . . . . . . . : 123.237.89.1
ip address and default getway would be different at your end, type the default gate way in he browser and try to open the interfce.
else use this start --> run --. type "http://192.168.2.1" and than enter. this must work at times.
Posted on Jan 24, 2009
  • vishal reddy
    vishal reddy Jan 27, 2009
    Lets try this,
    unplug the ethernet chord and open command prompt..
    type "netsh int ip reset resetlog.txt" and push enter..
    than type "netsh winsock reset" and push enter"
    you would have the following window in the dos...
    C:\Documents and Settings\Vishal>netsh int ip reset resetlog.txt
    C:\Documents and Settings\Vishal>netsh winsock reset
    Sucessfully reset the Winsock Catalog.
    You must restart the machine in order to complete the reset.
    plug the ethernet cable from the router to computer,
    Restart the computer.
    this basically resets the stack of TCP/IP on the computer.
    check if that works and please keep me updated.
    Regards,
    vishal
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
I'm trying isolate parts of my network and I need to place a Dynex 4-port router right after my modem and then plug my office lynksys router into that. (At present, the linksys is plugged into the modem...
Modem <--> Dynex <--> your computer should work.
Connect:
Modem <--> Dynex <--> Linksys router <--> your computer.
Turn off all the above devices.
Turn the modem on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Dynex on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Linksys on, and wait for its lights to "settle" down to a repeatable pattern.
Turn your computer on, and wait for its lights to "settle" down to a repeatable pattern.
On your computer, click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
The Linksys router should have given you an IP-address for your computer, and the IP-address for the "gateway" (namely the Linksys router).
Start your web-browser.
Type http://192.168.0.1 (or http://192.168.1.1) to connect to the web-interface "inside" the router.
Access the 'WAN' settings-page on the router, to see what IP-address the Dynex router has given to the Linksys router, and what "gateway" IP-address that the Dynex router has offered to the Linksys router.
It might be best to change the range of "dynamic" IP-addresses that one of the routers hands out, e.g., '192.168.123.100' to '192.168.123.200' for the Dynex router, so that both routers don't try to hand-out IP-addresses in the *SAME* range.
Apr 05, 2010 | Dynex 4-Port Ethernet Broadband Router...
I need to find my dns and secondary dns for a dynex wireless g router
Try typing your IP address into your browser (Internet Explorer)
Hope this helps!
Feb 06, 2010 | Dynex Enhanced-G Wireless Broadband Router
How do you hook up a dynex 802.11g wireless router
To setup your Dynex router you can follow the below steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.0.1 and then type the username as "admin" and the password is blank so leave the password box as blank
  5. You need to set it up as per your internet service provider if you do not have any fixed IP address provided by ISP then select dynamic IP address and then click on clone mac address after saving these settings on the router setup page you can check if you are able to access internet then you can do the wireless settings
  6. Once the router setup page is open you can confugure the router easily without the CD setup.
  7. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  8. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  9. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  10. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  11. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
Dec 03, 2009 | Computers & Internet
Cant connect to internet
Configuring router for Cable Internet (LINKSYS)
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Configuration Steps:
Step 1
Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' for password and username is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection Type to 'Automatic Configuration (DHCP)' option. Under Setup, click on MAC Address Clone tab. Enable it and click on "Clone My PC's MAC". Do this from the computer which the cable modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router.
Step 4
Click on SAVE SETTINGS and then on REBOOT THE DEVICE including the cable modem to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.1. You can do this on your router under Setup > Basic Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Sep 02, 2009 | Linksys Wireless-G WRT54GS Router...
Did not get the resource cd with my dynex 4 port 10/100mbpsrouter
Of all the routers mentioned in this forum, I know of none that need anything but a computer connected to the router. Each one of these has a setup wizard which is accessed from a web browser.
Here's a manual if you don't already have it http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Installation%20Guide.pdf
You plug a PC into the LAN port, open up Internet Explorer, and type in 192.168.0.1 in the address bar, and your wizard will come up.
If it doesn't, then post back and we'll talk about setting your PC's IP address.
Carl
Mar 19, 2009 | Dynex 4-Port Ethernet Broadband Router...
Router
Wijth the router CAT5 cable connected to the host computer, open internet explorer on the host computer, in the address window type http://192.168.1.1 then press the ENTER key. If 192.168..1.1 is the correct IP address of the router you will get the logon screen of the router. BPCS
Dec 28, 2007 | Dynex DX-E401 Router
Dynex Wireless-G USB 2.0 Network Adapter Logo
440 people viewed this question
Top Dynex Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
