Question about Canton AS 15 SC Subwoofer
Canton subwoofer As 15 SC.
When it's connected regradles if anything plays or not the significant noise (buzz) appears
2 Suggested Answers
  • 867 Answers
SOURCE: how do i connect subwoofer (canton movie 125 mx) to amplifier(onkyo txnr609)? there is one subwoofer output on the amplifier with either L & R(mono) high level input or L & R(mono) low level i
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
Posted on Mar 10, 2012
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud buzzing noise.
If you pull out the "input" cables and the noise stops, you have a problem with the "ground" and you have to check if there isn't a loose contact inside the plugs. If it doesn't stop, your amplifier is the problem and that mostly is a bad contact on the board in the pre-amplifier area.
May 05, 2013 | Definitive PF 15TL+ Subwoofer Speaker
I can't get my reciever to play my subwoofer
The sub channel will be switched off. You need to find the speaker settings, locate the sub channel settings and switch it on.
Jun 16, 2017 | Yamaha RX-V663 Receiver
In love
Please provide more details...valenyine is around the corner
Feb 09, 2011 | Canton AS 60 SC Subwoofer
My Canton ergo 22 DC speaker has developed a buzzing behind the music. The buzzing goes away when I tip the speaker over at least 45 degrees. I also found that, reaching inside, the buzzing goes away...
The screen is press-fit into a channel around the periphery. A small hook like a dentist's tool or similar device can pull it away.
Do so carefully, as any bend will make refitting them a chore.
If loose screws are not the culprit, perhaps the cones are sagging with age. If they are silent when you invert the cabinets, consider pulling the woofers and reinstall them upside-down do counter the effect of gravity over time.
Jan 19, 2011 | Canton Ergo 22DC Speaker
Buzzing noise when played on big stereo from cable?
you need a loop bypass filter. you can buy them at walmart for 10-15$
Apr 30, 2009 | Car Audio & Video
Buzzing Noise in Sound Studio
hi, check all cables,clean connections. i have had these kind of problems in the past. also coulb be ground loop!? hope this is helpful.glen
Feb 15, 2009 | Apple Griffin iMic External Sound System
Canton AS 15 SC Subwoofer Logo
42 people viewed this question
Top Canton Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Canton Audio Player and Recorder Expert? Answer questions, earn points and help others
