Question about HP Compaq Presario V5000Z Notebook
Is my presario v5000 using my ram upgrade
I upgraded my presario v5000 with one gig of ram. now it seems that its running slower then before. the control panel says i have 1.26 gigs but the computer does not run like it.
  • 43 Answers
Where did the ram come from? did you buy it or pull it from another computer? its possible the chip is either defective or not for your computer depending on where you got it, its also not that much of an increase so you may not notice it i would suggest getting another 1g stick because yours should take 2g 1 in each slot.
Posted on Jan 24, 2009
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
Ram upgrade maximum slots memory
http://www.crucial.com/index.aspx
Go to this web site and follow the steps and it will help you find out what you need to up grade your laptop.
Dec 02, 2013 | Compaq Presario Notebook
I own a compaq presario 6450nx and I would like to upgrade it. like adding more ram and replace the cpu if its posible, what could be the suggestion?
This is info on your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Your system comes with Intel P4 2.53 GHz processor and 512MB ram. total ram could be 1GB, bt adding another 512MD stick. You have Socket 478 and processor would be up to you. The system comes with a 200w power supply so, in an upgrade, you should up the power supply. You have an AGP expansoin slot and, you could upgrade to a graphics card but again, power supply is only 200w. The system as it stands is not Windows 7 compatible. If you incraesed your ram and got a graphics card, you would get better performance.
Jun 13, 2011 | Compaq Presario 6450NX (DA238A#ABA-BDL1)...
I HAVE A COMPAQ PRESARIO 5000 DESKTOP THAT RUNS VERY SLOW AND WHEN YOU GET ON THE ENTERNET IT RUNS SLOWER TO LOAD A PAGE IT SEEMS TO BE MORE SLOWER
check your ram and see if you at 768 mb which is the most you can install. unforntunately that isnt the best but if you can upgrade you will get more speed.
Jan 16, 2011 | Compaq Desktop System w/ 17'' CRT Display,...
I have bought a compaq presario 1200ap i want to upgrade the ram what should i use 100mhz or 133mhz some websites say either can u help plz
Does not matter, the laptop runs at the 100 mhz speed so the 133 mhz memory will simply run at the slower speed.
May 24, 2010 | Compaq Presario 1200 Notebook
Each day my computer seems to run slower and slower.
Run the commands in your Accessories and also don't forget you need to Defrag and run an Anti-Virus software. The proper programs are under Start>All Programs>System Tools>Disk Cleanup and Defrag. When the housekeeping is done, if your computer is still running slow then the best thing you can do is upgrade the amount of RAM. That will make a noticeable difference.
Please rate this solution.
Jan 09, 2009 | Compaq Presario V5005us Notebook
Ram on the HP 530
Yes a 512 or RAM can run a Vista system but it will be much slower so if you want to be able to use the Vista systme to the fulless better if you upgrade the RAM of your computer to atleast 1 GIG of RAM but 2GIG will be much better so Vista will work smoothly....
Nov 17, 2008 | HP 530 Notebook PC
Upgrade ram
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
May 22, 2008 | Compaq Presario M2000 Notebook
Memory
if it is windos xp then it wont recognise
Feb 08, 2008 | Computers & Internet
Memory upgrade
try with reomiving temperoroy file and delete file or programmes from statrup uninstall unwanted software and run chksdk utility and check for virus also. if you still facing the the problem i will advise you to take a backup of your system and format and reinstall opreating system
Oct 06, 2007 | HP Media Center m7060n PC Desktop
HP Compaq Presario V5000Z Notebook Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
