Question about Sharp Microwave Ovens
Sharp carousel R 395y 1200 watts keeps making buzzing noise
Microwave oven works perfectly except for buzzing noise have pulled out plug and switched back on
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
SOURCE: Sharp r-1481 950 Watt microwave oven problen
Found the answer by calling a Sharp technician and they said it was the magnetron tube, which is not worth fixing :( Thought I'd pass this on to anyone that has yet to find out.
Posted on May 16, 2009
  • 3230 Answers
SOURCE: Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Posted on Aug 24, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The number display on my Sharp R-515EK 1200 watts microwave oven
We regularly repair these control / display units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 31, 2009
SOURCE: sharp carousel II microwave/convection oven
Hello, I just purchased a Sharp Carousell II convection microwave oven, also built in 1990, serial number 212806. I think the model number is R18244, but part of it is worn off. Can anyone tell me how to get a manual for it? I have never cooked with a convection oven before.
Thanks
Posted on Nov 14, 2009
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
Microwave arching
faulty microwave module replace it
Apr 22, 2015 | Sharp R530EWT Countertop Microwave Oven...
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
My microwave is 25 years old, will it be working to maximum efficiency
If all the settings work and the door closes ok . why throw it out ?. It may not be quite as efficient power wise as a brand new one. the few cents extra to run it against the price of a new one, I would stay with old faithful.
Dec 31, 2014 | Sharp R530EWT Countertop Microwave Oven...
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Sharp carousel R 430 EK 1200 watts
This is not good, the magnetron is arcing because metal is exposed, this will eventually destroy the magnetron making the oven useless. I strongly suggest it get looked at for safety and potential fire hazard.
Mar 05, 2012 | Sharp Carousel R530EST Microwave Oven
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
