Question about Hoover F6030-900 SteamVac WidePath Wet/Dry Vacuum
Hose under Steamvac F6030 is torn.
The hose on the underside of the cleaner that feeds into longer hose is torn off of the attachment part.
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Dec 06, 2007
reddevil6
  • 1673 Answers
SOURCE: Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Posted on Mar 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
Posted on Apr 20, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
dbqsaints
SOURCE: Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from http://www.appliancepartspros.com/. (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Posted on Feb 16, 2012
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Could the hose on steamvac be saved
The hose for this model when torn can only be replaced. With a torn hose you will loose suction from your floor nozzle, and performance will be decreased.
Aug 12, 2014 | Hoover Vacuums
Hoover SteamVac F6030-900. Does not **** up
check the black plastic motor cover. these frequently melt and loose seal due to the extreme heat of the motor. if the plastic is warped, then that is the problem. also check for hair and cloggs throughout the suction ports
Feb 26, 2010 | Hoover F6030-900 SteamVac WidePath Wet/Dry...
Water leaks out under the unit when using the upholstery attachment?
You may wish to check and see if the leak is where the small water supply hose is plugged in to the cleaner base. That connecction supplies water from the product, to the spray end on the upholstery hose.
Sep 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Superscub attachments won't work
It sounds to me like you have the water hose plugged in, but not the hose block. In the front of the dirty water return tank there should be a removable square plastic piece. Remove the lid and slide that piece out. Replace wth the back end of the hose receptacle. If you have already done this, then here is your problem: when you return the lid to the top of the return tank, you must roll it on from the front(there are brackets the lid hooks under) to the back and listen or feel or the "click" your tank is now ready to pick up the dirty water from your hose. let me know if this helps!
Aug 06, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
How to attach the upholstry cleaners
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
May 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Attaching the attachments
Take off the brush that is on the end of the hose, then attach your stair cleaner on the end of the hose.
Sep 23, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Problem hose
Try gently feeding a thin, springy wire down the tube to find is there is a blockage further up.
Mar 22, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F6030-900 SteamVac WidePath Wet/Dry Vacuum Logo
66 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
