Question about Bosch Kitchen Ranges
Crackling noise when changing speeds on extractor hood - is this normal or is there a problem with the extractor hood?
3 Suggested Answers
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
Have a Neff D9610 cooker hood. Has 3 separate speed switches. Slowest speed switch does not work other ok. No noise from motor when slow switch on. Is the problem with the switch or the motor?
When on high speed the motor is running at it's normal speed.
When a slower speed is selected (mostly) there is external circuitry to reduce the current to the motor so it runs at a slower speed, though in some cases the motor could be specially wound for multiple speeds. The latter way is unlikely to be found in a cooker hood or extractor fan or other small appliance.
The fault with your appliance could be the switch or the current reducing circitry. It is only by delving inside and testing that the fault could be found.
Oct 02, 2016 | Cars & Trucks
Lifter noise
by changing the exhaust I take it that you removed the standard exhaust manifold and fitted extractors in instead. The noise may not be lifters but a exhaust leak form the exhaust not being fitted properly (gasket ) or just and gas noise as the exhaust valve opens that is normally silenced by a stock manifold.
Jan 03, 2014 | Infiniti Cars & Trucks
Kitchenaid ksb465 electrical noise.
Arcing at the brushes is normal although if worn down enough, they can skip since their travel is limited to avoid damaging the copper commutator.Look at the brush guides closely; the simple spring that supplies a little tension to the brushes will 'bottom out' on a slot in the guide once the brushes get too short.
The skipping might be due to the type of speed regulator that is used; an older type was mechanical and didn't regulate well at low speeds.
Dec 30, 2011 | KitchenAid KSB465ER 4Speed Blender
The fan has three speeds. The highest speed is very loud! More than twice as loud as the middle speed. Is this normal? Unit is a KWCU360JSS-1
Yes, it is normal. Actually the energy into a fan is related to the third power or cube of the speed. The turbulence of the air contributes to the noise as well as vibration, etc.
Jun 07, 2011 | KitchenAid Pro Line KWCU360JSS Kitchen...
Sound comes and goes on the drive channel, and there is a strange crackling on the clean channel. i dont know if its the tubes, the speaker, or electronics.
Using a common lead pencil, gently tap on the smaller tubes in the unit, listening for noises and crackling to change and the drive channel changes.
It is normal to get a slight twang when doing this from the microphonics of the tubes, however, the crackling and up and down volume points to a bad tube.
Sep 03, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hi. How can I tell if the charcoal filters in my Smeg cooker hood need replacing? They cost £80 so I don't want to replace them unecessarily.
Firstly operate extractor normally,hold a piece of A4 paper on the underside of fan and see how it holds it on the different speeds.Then if you can remove the charcoal filters then operate as before and compare the difference between the suction,this should tell you if it is the charcoal filters or a blockage in the pipe.
Hope this helps
Jan 25, 2010 | Kitchen Ranges
Crackling noise around the console
Open your hood on the firewall on the passenger side youll see the heater blower see if you can hear same from that
Mar 06, 2009 | 1999 Lexus RX 300
Dec 20, 2008 | Imperial C2036PS1-TW Kitchen Hood
Baumatic cooker hood lights not working
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Kitchen Ranges Logo
24 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
