Washer has stopped and showing error f08
SOURCE: Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Whirlpool washing machine showing a code of F08
That is an overflow condition.
Check the drain hose and make sure it is not plugged or kinked
Check the wire harness to the drain pump, pressure switch and Central Control Unit
Check and clean the drain pump filter of foreign objects
Check for drain pump failure
Check that the inlet valve shuts off fully
Check that the pressure switch is operational.
