Question about Protron PLTV-32 Television
Picture is a box does not fill the screen - Protron PLTV-32 Television
    Problem Solver:
  • 15 Answers
Check menu settings, ypou just need to stretch the screen size.
Posted on Jan 24, 2009
Picture out of screen on all sides from ariel and digibox
Your tremote should have a format or aspect button. Push it untill the picture fills your screen currectly. If this does not help, then you will need to find the screen settings on your cable or sat box.
May 29, 2016 | Samsung Televison & Video
LG 55ln5700 picture does not fill screen
Go to picture/video settings and make sure your screen size is set for 16:9 or wide screen ratio.............
If you have dish or cable go into menu settings and check and make sure the same is true
Sometimes on the remote there is a picture size/mode button you can press to change the screen size
Normal or Wide would be widescreen
Stretch is zoomed picture that fills the screen
Letterbox is the square box screen
It sounds like a picture setting problem to me
I would try those things first
Jul 09, 2013 | Televison & Video
I have a Vizio 55" TV model M55ONV. I can't
Are you using a cable box like a DVR?...there should be a setting on that for aspect ratio, not sure this is a TV issue
Dec 18, 2017 | Televison & Video
My picture is zoomed in. Cannot go back to 'normal' and see everything. Credit names, etc are cut off on both sides.
Hi
Thanks for using FixYa. First of all please check your cable box settings first. Sometimes the remotes have a picture size button on them, and someone might have pressed that by accident. Check the TV settings, press Menu Button & then go to Window/Image size. Now select Full Size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 26, 2009 | Sharp LC46SB57UN 46 in. LCD HDTV
I have an 42LG50 and the picture is now a smaller box on the screen and the manual is now help in enlarging the picture, any ideas?
You possibly have the screen set to the 4:3 ratio. On the remote control use the aspect ratio button to toggle through the different size screen formats eg 16:9 etc. this will enlarge the picture to fill the screen.
Nov 08, 2009 | LG 42LG50 42 in. LCD HDTV
Enlarge the picture to fit the 20'' screen
Reset the aspect ratio/ picture size from your remote or from the menu.
Apr 17, 2009 | Philips Televison & Video
I have a samsung 1080i 52" floor model tv. I don't have a remote or the instructions,. I have hd box from rogers and my picture doesn't fill the screen, Rogers said I have to do it either with a remote or...
you will need a remote to change the picture setting to make it fill the screen! try a cheap universeal remote that you can get at any wall mart
Dec 07, 2008 | Televison & Video
Tv stuck on zoom
Hi
Thanks for using FixYa. Please check your cable box settings first. Sometimes the remotes have a picture size button on them, and the in-laws could have pressed that by accident. Check the TV settings, press Menu Button & then go to WINDOW/IMAGE SIZE. Now select normal size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen. If still the issue persists, then you’ll need to go to the service menu. To go to the service menu please start with the TV off and press mute > 1 > 8 > 2 > power the remote on. Now the TV will come on with the menu displayed and from there you can change the settings as required.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 27, 2008 | Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Protron PLTV-32 Television Logo
19 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
