Question about Siemens Ovens
How to replace function selector knob for Siemens HB480GB
4 Suggested Answers
  • 22 Answers
SOURCE: retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Posted on Jul 02, 2007
bestdarngood
  • 3037 Answers
SOURCE: Replacing a function selector knob
They are very easy to replace. All I need to do to replace it is, pull it off. You can use a blunt object such as a butter knife to help you lever it off if you're having trouble.
Then, get your new one and it'll only go one way so make sure its facing the right way, and push it on! Here is a short video for demonstrating how to do it.
http://www.espares.co.uk/advice/cookers-and-hobs/a/1/1336/how-to-replace-the-control-knob-on-a-neff-ove.html
Let me know if you need anything else.
Benjamin
Posted on Nov 04, 2010
  • 228 Answers
SOURCE: I need to remove the control panel to replace the
HI
you dont need to remove panel to replace, it literally just pulls out from the front as a complete assembly you may find using the edge of a teaspoon helps to draw it forward without marking the steel use the curved bowl of the spoon against the steel.
if the knob is damaged from heat escaping (melted) make sure you grill with the door closed.
Posted on Feb 22, 2011
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
Where can I get a replacement "Oven Function Selector Switch" for a BOSCH OVEN - Model No. HBE632UAU/03 (Year of Manufacture 1991) Part No. 05 5870 which was later replaced by Part No. 05 9863. The...
try going to goole.com and put in appliance parts there will be a number of sites that will come up many in the USA that have many parts.
May 16, 2014 | Ovens
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
The temperature selector wont turn off
Sounds like your temp setting knob is bad. Try to reset the breaker and see what that does. Reset it even if the breaker is not showing tripped.
Feb 24, 2013 | Bosch Ovens
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
I need to remove the control panel to replace the Function Selector (knob) how do I remove the panel? Thanks
HI
Feb 22, 2011 | Neff B1421 Electric Single Oven
Benjamin
Nov 04, 2010 | Neff B1641 Single circotherm super...
Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Jan 20, 2010 | Creda Europa E010E Electric Single Oven
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Retractable function selector knob stuck
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
Ovens Logo
32 people viewed this question
Top Siemens Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Siemens Oven Expert? Answer questions, earn points and help others
