Question about Ingersoll Rand 39875539 Pressure Transducer
Whats wiring diagram for 39875539 transducer - Ingersoll Rand 39875539 Pressure Transducer
I have a Garmin 2010c on my boat and turns off every 10mins.. what can be the problem?
Bad connection or a fault to the unit.
Do you have it on a separate battery? It is best if they are, or connect direct to the starting battery, not connected via power that you find in the console or on a power bar.
Make sure you are using good quality copper stranded wire of the correct gauge with soldered or properly crimped connectors. I think it is 18 gauge, but your installation instructions will guide you. Also mentions 24 AWG. Manual states;
Wiring
There are two wiring diagrams provided for you convenience. The first is a simple hook-up showing the GPSMAP 2006/2010 (using the 18-
pin wiring harness), the GPS 17 and the alarm circuit. The Alarm does not have to be wired for the unit to function. The second is a complete
wiring diagram showing the GPSMAP 2006/2010 (using the 18-pin wiring harness) interfacing with a variety of different equipment. The extra
5-pin wiring harness that came with the unit is intended for future interfacing features and does not require connection. Refer to the wiring
diagram that will best suite your needs. Make sure that all connections are good. For extra lengths of wire, 24
AWG (unless otherwise noted on
wiring diagram), shielded, twisted-pair wiring is recommended. We advise soldering all connections and sealing the connection with heat shrink
tubing. If you experience difficulty wiring the unit, please contact an installation professional in your area.
Make sure the connections are good on the rear of the unit including plugs to the transducer. You can coat with a little Vaseline which his electrically conductive.
States the unit is susceptible to RFI and should be 3 feet away from a radio antennae.
Finally, make sure the inline fuse and connections to it are good.
If all that seems good, the first thing to do is swap out the transducer for a new one. Still does it? Send the unit for repair.
Does it also do it at rest in the marina, or do you trailer the boat?
I have a Humminbird 998 HD Si.
http://static.garmin.com/pumac/47_2006_2010_GPS17Installation.pdf
Jul 29, 2017 | Garmin GPS
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
Wiring diagram for Lowrance HDS7
go on line to lowrance get your wiring diagram off line
Jan 09, 2013 | Lowrance HDS7 Insight USA Multifunction...
A/c wiring diagram for 2006 jeep liberty sport
I am sorry but fixya has no wiring diagrams for any car or truck. I suggest you try this site www.alldatadiy.com
Apr 13, 2012 | Cars & Trucks
I have a very old Si-tex pro II finder that im trying to get running can any give me a diagrame of how the wiring. the coulors of each wire does what? witch plug/wires runs to the tranducer??? Thanks Sam
Hello, Ticle33 did you ever get he hold of a wiring diagram for the si-tex profish II? I am in the same situation and cannot find one. Hope to hear from you. Thanks /Tom
Aug 07, 2011 | SI-TEX Profish Ii Without Transducer 6"...
I want to see the schematic diagram of humminbird fish finder transducer, my fishfinder won't operate. if i plug another unit of transducer, the my fishfinder operates normally.
Hi Greg and Ernesto:
Re-stating the obvious, your transducer is not working but you know that the sounder is.
I would start by checking to see if your transducer works on a different sounder. That's just a double check to confirm that it really is not working.
Then I'd try to isolate the problem:
- Plug (couold be corroded or damaged)
- wire (could be broken)
- Transducer (could be defective)
Since these are sealed units, I'd be checking with the supplier to try to find a replacement. Hopefully they are not too expensive, and time spent fishing is better than trying to maybe save a few dollars, especially if you're taking out charters.
Best of luck.
Sep 01, 2010 | Humminbird Fishfinder 525 406260 1
Looking for a wiring diagram / pin out on the air conditioning electrical connections for the pressure transducer on a 2006 dodge diesel
your local public library should have great resources online for free you can access with your library card just a suggesrion because online i find wiring diagrams to be expensive.
0423b4e.jpgdoes this diadram help? ihad to reduce the size for the forum hope it is readable
Apr 24, 2009 | 2006 Dodge Ram 2500
Need older Raytheon v720/ v820 sounder transducer pinout
Did you find it? i´m triying to get a wiring pinout diagram for a V8010 transducer. Thanks, regards from Spain
Apr 21, 2009 | Televison & Video
Transducer
I have the exact same problem. Were you able to solve your problem???
May 12, 2008 | Garmin GPSMAP 3210 GPS Receiver
Ingersoll Rand 39875539 Pressure Transducer Logo
61 people viewed this question
Top Ingersoll Rand Garden Experts
Dennis Key
Dennis Key
john h
Are you an Ingersoll Rand Garden Expert? Answer questions, earn points and help others
