Question about Microwave Ovens
My mw8115 just quit working, does it have a fuse that i can replace
  • Anonymous Jan 24, 2009
    one minute it was working the next minute everything went out
  • 52 Answers
Open the casing and check the fuses inside, there are several so check them all
Posted on Feb 21, 2009
Where to start in troubleshooting?
There should be a fuse some where in the works. Mine quit and I replaced a fuse and is ok now.
Mar 31, 2015 | In Microwave Ovens
Emerson model mw8115 ss
The problem is caused by one or two bad door switches that will need to be replaced.
Mar 14, 2012 | Emerson Fans Emerson MW8115SS Microwave...
Where is the light bulb in a emerson mw8115
It is inside the outer shell of the microwave, remove the outer shell to access the bulb, the srews that hold it on are on the back of the oven. You will need to disconnect power of course and do the work in an area that alloes you access to rear of the oven.
Please rate my help for Fixya, it helps to improve my standing on the site. Thanks
Jan 18, 2012 | Emerson Black Microwave Oven
It just quit working. checked the circit breaker and unplugged for the recommended time- still not working
inside the control panel up at the top you wll find the fuse . remove grill and one screw to panel and open remove fuse and replace with same 15 amp type fuse . . i think this will solve problem . ****
Jan 04, 2010 | Maytag Appliances Over-the-Range Microwave...
I have a JES 1456 GE Sensor microwave oven purchased at Walmart about 3 years ago. It has worked great up until now and it just quit. It is blacked out and does nothing. It quit without a sound while in...
Sounds like you have a thermal reset opening up on the unit and disabling it till it cools down. Make sure all air intakes are clear of debris, papers from the counter , etc. also make sure no dust covering air intake holes. Do you hear a fan running when the unit starts?? If not, bad fan, burnt wires. bad main board. Like a lot of my other posts, maybe a bad fuse and fuse holder. Check for brown flux coming out of shiney metal end of fuse, where it meats the ceramic body. Replace fuse and fuse holder. Sometimes fuses do just get tired and barely open, not actually blow, then just expansion and contraction of the element inside will make the unit work and then quickly shut off. Cheapest way is just sub the fuse and give it a try. Cost you a dollar or two, if that works replace the fuse holder too.
Aug 18, 2017 | GE JES1456 Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
I need a user manual for the mw8115ss emerson
Go to this web site.
http://www.emersonelectronics.ca/emerson/en/support/index?page=manuals
where it asks you to input your product code, type in "mw8115" (without the quotes) then click "go"
Please take the time to rate this solution
Jan 28, 2009 | Emerson Black Microwave Oven
Nothing working - just quit. Power source ok.
There are 3 fuses in that microwave. I had a similar issue. The one that I had to replace was the little ceramic fuse that is in line after the big fuse which is connected to the main line.
I couldn't find the ceramic fuse but I replaced it was a glass one about a year ago and it has been working since then. The fuse if located on the right front panel.
Dec 29, 2008 | Whirlpool MH3184XP Microwave Oven
My Emerson MW8115
Hopefully it was not an unheated storage area! Moisture and contamination can get into the controls from condensation due to big changes in air temperatures in areas like unheated storage units or garages. That being said, the most common causes of a failure to heat are in order: - bad door switches or door switch mounts - loose connection at the magnetron - problem with the control unit - bad magnetron or other high voltage part At our site, we have critical safety information, info on door switch diagnosiss and replacement, and disassembly information. You can find us via our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 05, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
