Question about Casio watch PRG250 Casio Protrek Tough Solar Triple Sensor Watch PRG-250-1
Replace battery casio prg 250T - Casio watch PRG250 Casio Protrek Tough Solar Triple Sensor Watch PRG-250-1
I need to buy strap only for model prg-110b
Go to your local Jewelry (watch) H samuels , HINDS bout expect to pay a lot .
Dec 24, 2015 | Casio Protrek Triple Sensor Prg 110T 7VDR...
Casio PRG-80L reads open
Have the same problem, Casio PRG-80L reads open. No hints about this in the manual. Nor did Votit's suggestion help. Note that although the watch is old there is clearly power left in the capacitor battery. Ended up accidently ito this mode when resetting the time. Assume the open mode is intended for service, but would just like to exit.
Nov 03, 2012 | Casio PRG-40T-7 Pathfinder
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
Battery replacement
You can do it yourself. Unscrew watch caseback and undo the contact on top of battery. Read the writings on battery and buy exactly the same one. Do not mind manufacturers (Casio, Maxell, e.t.c.), just make sure the numbers are the same.
Some watch casebacks can be opened only if the watch band is removed, so, remove it if needed, just don't forget to memorize where every part and screw was fitted. Memorize how the battery is fitted and do not put the new one the other way around as this can damage your watch.
Actually there is nothing difficult - only you have to put everything back exactly the same way as it was. If your watch will be left without battery for more than 3 minutes, you will need to reset your watch after replacing a new battery, but it's easy if you've got users manual.
Good luck.
Do not forget to rate, please.
Mar 11, 2009 | Casio PRG-40T-7 Pathfinder
I need a REPLACEMENT CTL 1616 battery for my Casio PRG-60
I found one of these on ebay. Here's the item I ordered.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310129530689
I used the instructions here to replace the battery myself:
http://forums.watchuseek.com/showthread.php?p=226461#post226461
Hope this helps.
Mar 03, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio Pathfinder Digital Compass will not calibrate
http://pathfinder.casio.com/support/manual/
find your watch and use the manual. if there is no solution then take it in for repair. any Casio retailer should have repair center information.
Jan 25, 2009 | Casio PRG-40T-7 Pathfinder
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio watch PRG250 Casio Protrek Tough Solar Triple Sensor Watch PRG-250-1 Logo
46 people viewed this question
Top Casio watch Watches Experts
k24674
jamulder513
Are you a Casio watch Watch Expert? Answer questions, earn points and help others
