Question about Maytag Atlantis MAV6000 Top Load Washer
Is there a reset button?
With a full load, it did not go into wash mode. I began to smell an electical burning odor. I turned it off and emptied out the water manually. Is there a reset button?
  • 65 Answers
THERE IS NO RESET BUTTON ON THE WASHER, ONLY THE OVERLOAD AND THERMAL LIMITER ON THE MOTOR. SOUNDS TO ME LIKE THE MOTOR IS BAD, BUT CHECK TO MAKE SURE THAT ALL THE PULLEYS TURN FREELY ON THE BOTTOM OF THE MACHINE BEFORE CONDEMNING MOTOR.
Posted on Jan 26, 2009
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
I have a maytag model# mav2755aww, I have a burn smell when it's in the spin cycle. yes it is spinning the water is draining ?
Burning odor may be coming from a overheated motor under a heavy spin load.
Before going any further;
1.Make sure the circuit breaker for the machine is working properly and know its location.
2.Have a working fire extinguisher nearby.
3.If a electrical/motor fire starts, you need to turn off breaker power to the washer..Then use the extinguisher to put out any fire.
Try spinning the basket empty and see if the odor still persists if so, you need a new motor ..
If not, you have to think about the weight of the washload that the spin cycle must handle..
If a light load causes the same odor, stop using the machine until you replace the motor and check the transmission for any problems.
Oct 02, 2014 | Washing Machines
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Odors, the machine smells very much like mildew
Cure 2 cups of bleach large load water setting, hot water let set 2hrs full of water run washer empty "no clothes just hot water" 2 times normal wash setting, repeat if nessary.Note : Not all of the water drains from a washer the water left in yours spoiled, bleach should take care of it.
Nov 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Odor in clothes
run an empty load in the washer but add 3 cups of vinager and set the washer to hat wash, this will help kill the smell, After you get done running it leave the door open this will stop it from happening again
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
350 chevy Lost compression and engine began to smoke.
pull out your spark plugs and try cranking the motor again, see if you're spitting out coolant from the plug holes. I'm asking you to do this, cuz it sounds like you blew a head gasket.
Mar 02, 2009 | 2000 Chevrolet Blazer
Foul water odor after wash
There is always a littlee water left in the sump of a washer after it is emptied. If the washer sits unused for as little as 2 or 3 days it can have that odor. One thing that I do is add about 1/4 cup of ammonia after the washer is full of water. DO NOT USE AMMONIA IF YOU USE BLEACH IN THE SAME WASH!!! IT WILL CAUSE CLORINE GAS TO BE RELEASED!! If bleach was used in the previous cycle it will be ok.
Feb 28, 2008 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Reset button on washer???
our washer smelled like burning and reset button totally fixed it, it was under screwed down panel in back
Dec 08, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
LG WD-1234FH
You will need to have it checked by a qualified LG technician to see what is the deal with the burning odor.  And the noise is probably the washer not balanced correctly.
Oct 28, 2007 | LG WD-1080FD Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
246 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
