Question about GE Profile Harmony DPGT750EC Electric Dryer
Thumping while drying
I have a DPGT750EC2PL that has been making a thumping noise for the past several weeks while drying. It appears as if something is out round.
  • 3 Answers
It is probaly not the front felt seal but the bearing the drum turns on.
It is located in the middle of the drum at the back.
You will need access to the back of the dryer to fix.
It is realy a pretty easy fix and will save you a bunch of money.
The bearing looks like a flat plate with a tiny trailer hitch ball. I kid you not.
Open the top which is hinged in the back, pry the front up ,but be carefull to to chip the finish.
Its tight but no screws usually.
Find the screws to take the front door/panel off. With the front off and the belt pulled loose you can pull the drum out of the socket from the back of the dryer.
Buy the part first and you will see a lot of what you need to do. Use the high temp grease( included in kit) freely in the socket.
Then assemble the reverse way you took it apart.
Put the belt back on the drum and route around motor pulley, before the door assembley.is put on the front.
Then on your knees or belly reach back by the motor and put tension on the idle pulley, ( pulley not on the motor.)
Route the belt around the motor pulley and the idler pulley so when you let go it tightens the belt.
Posted on Feb 08, 2009
It's not a bearing...
It is the SEAL and BELT in the front of the drum. These are parts that are intended to wear out over time. They hold the drum in place as it turns. Since they are worn -- the drum is no longer balanced and thus thumps as it turns. When the dryer is off... you will notice that you can giggle the drum by hand... this should not occur when you have a good/new SEAL and BELT -- approximately $75 in parts
Posted on Feb 02, 2009
    Genius:
  • 2,920 Answers
It soundslike the bearingare going out
Posted on Jan 24, 2009
Constant thumping noise
your speaker is compromised there is no fix only replacement
Jan 05, 2013 | Bose Companion 3 Computer Speakers
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Thumping noise
Sounds like the tub is unbalanced from either a bearing/pulley suspension problem or the unit has broken something off in between the tub and outer portion of the unit before you get to the walled panels, and you are hearing a rubbing and thumping noise. This is not a typical DIY job since the entire back panel of the unit needs to be pulled off and diagnosed.
Sep 18, 2012 | Frigidaire FEQ1442ES Electric Dryer
What is the cause of continual thumping (appears to be coming from back of car) and violently shaking?
Many times, rear tires that are out of round or severely cupped or feathered, or that are out of balance can create this type of issue. My first recommendation would be to have them and the wheels on the rear of the car inspected. There may not seem like there is much wrong visibly if you look at just the tread of the tires, but a good tire tech can spin them up and give you some solutions, and the inspection itself is inexpensive. Hope this helps.
Jun 19, 2012 | 1997 Nissan 200SX
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Air handler fan appears to cause thumping noise
If it's a belt drive check the belt or the pulley could be worn. If it's direct drive check to se if something is in the fan wheel causing it to be out of balance.
Sep 11, 2009 | Heating & Cooling
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Thumping noise in chevy tracker 2000model
this noise sounds like your right cv axle. wou might want to have that checked out, they can do great damage if broken while
Feb 20, 2009 | 2000 Chevrolet Tracker
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Thumping noise in atlantis dryer after drying heavy mattress pad
Have you husband do a visual inspection of the drum and literally feel it to see if anything is caught or stuck on the drum. The motor also may have something caught in it as well. This would be the motor that turns the drum.
Dec 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
424 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
