Question about Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I have a Ultra Wash Dishwasher. The other day, i tried starting the clean cycle and nothing happened. The normal wash light keeps blinking. I tried to push the cancel button and nothing happened. I cycled the power and tried again with same results. I tried the power again and hit the cancel button and it started to drain then stopped. I then read on line to try to reset it. It started up like normal but after about 10 minutes into the cycle it stopped and the normal wash light is blinking again.
Please help. I'm having the same problem. My dishwasher clean light blinks 7 times every 5 seconds. Dishwasher won't start. I can press any of the wash or rinse cycle buttons and then start and the start just blinks red but does nothing. I heard there is a reset switch but I don't know where it is. Can you help???? My Kenmore Ultra Wash has a continually blinking cancel/drain light. I have read many button pushing combinations and several have worked but none have been a permanent solution. Within minutes, hours and sometimes days, the light starts blinking again. Is there a permanent solution other than replacing the dishwasher as it is only a year and a half old.
    President:
  • 1,214 Answers
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
2 Suggested Answers
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
1,734 people viewed this question
Top Dishwashers Experts
