Question about New Balance Womens ECG Workout Watch
Keeps beeping
Ecgaccurate heart rate touch technology
How do I turn off beeps on my ekho E-15 watch
Go into the menu, turn off alarms, beeps and chimes.
Oct 10, 2012 | EKHO E-15 Heart Rate Monitor Watch
It just keeps beeping and is not displaying anything but the little heart on top right
#1-check to make sure it doesn't need new batteries
#2-make sure that you are placing the cuff as directed.
#3-make sure that you are holding your wrist at heart level
The little heart and beeping only sounds to me like it is not picking up your pulse. Is the cuff tight enough before pushing the button?
May 19, 2010 | Omron HEM 650 Wrist Blood Pressure Monitor
My heart rate monitor keeps stopping picking up my heart rate (reading of 00 or --), i have changed the battery in the chest strap, not difference, any ideas?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all POLAR watch manuals. Rate me, please.
Mar 03, 2010 | Polar F11 Heart Rate Monitor
My heart rate is registering betwee 37 and 38...for resting. I know this is not accurate. This problem just started. When exercising intensely, it registers at 58 to 72. Any recommendations?
change you "HR view" to HR, not HR%. Currently you are seeing your heart rate as percentage of your Max Heart Rate (Max HR) but not by beeps per minute (bmp). Go in to the settings and see HR View.
Jan 24, 2010 | Polar F11 Heart Rate Monitor
How do i trouble shoot this unit
Call a company called Midnight Solar. They can help.
May 20, 2009 | Xantrex Technology xPower PowerSource 1800...
Precor C846 Recumbent Bike - heart monitor not working
You can test the HR grips to see if the wiring is good all the way from the contact grips to the upper board by doing a test with your meter. Get a meter that can test fuses and beeps if the fuse is good.
disconnect the 4 pin brown connector at the console board, on one side will be some metal contacts.
Touch one end of the meter lead to one wire and the other to the HR contact plate on the handlebar. try all the contact plates on the handle bar until it beeps, then move the lead to the next wire and repeat until all contact plates beep. It all of them beep then your wiring is ok and the problem is in the Heart Rate board in the console or the connection point on the board.
Let me know how it turns out.
Santafe
Apr 06, 2009 | Precor Exercise & Fitness
Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Dec 12, 2008 | Timex Ironman Triathlon Heart Rate Monitor
Heart rate monitor Results question
The ultimate goal of training with a heart monitor is to be able to run longer and faster with a lower heart rate. If you keep track of your results, there will be a couple of ways to see the progress. First, as you improve, you will see that running the same distances at the same heart rate will become easier. Effectively, you will be able to run faster for these distances without your heart having to work as hard. This is a direct reflection of increased efficiency of the heart. To see this, try running a set course - with your monitor - that is several miles long, and stick to a preset speed, perhaps your marathon pace. Then, under similar weather conditions, try the same course again a few weeks later. Run it at the same pace as you ran previously, and compare your heart rates for the two runs. If you've gotten fitter since your first run, your heart rate should be lower during your second. Another way to see results is to keep track of your resting heart rate by taking it down and recording it every morning before you get out of bed. Many trainers recommend that runners keep track of their RHR on a daily basis, and, as stated above in the RHR section, increased fitness should bring with it a lower RHR.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Nibp/Nellcor...
New Balance Womens ECG Workout Watch Logo
24 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
