Question about Xerox Phaser 8560MFP Laser Printer
Xerox 5755 won't detect #10 envelope - Xerox Phaser 8560MFP Laser Printer
3 Suggested Answers
SOURCE: Xerox Doc 12
Use the bypass tray. Use software that can override settings built into the RIP system if your using one. Freehand for example can do this while I cannot figure out how to get the adobe software to.
Set it to the envelope size in both page setup and freehand "advanced" in the print dialog.
To print them you have to unfold the top flap of the envelopes so the heat doesnt seal them and the paper sensor can pick it up.
Strange problem where is says no paper after each envelope, so I end up feeding one at a time. :( any solutions for that? I cant find the sensor
Posted on Jun 04, 2010
SOURCE: I have a Xerox Phaser 6180MFP and when I print #10...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
Posted on Mar 21, 2011
Xerox 5755 Install Phase incomplete error appearing on display
enter in diagnostics mood
then touch DC-131
then 03-machine run Control
change value (03-005) change to 4 and save
also change (03-018) change to 4 and save
exit from diagnostic mod and restart the machine
Jul 13, 2017 | Xerox Office Equipment & Supplies
Xerox 5755 prinnt quality low i mean print is light very tryng but print is a not set
That is a business quality, network, workstation. You would be advised to have it professionally serviced once a year.
If you want to try and do some work your self, all the documentation on it is here. The only thing I would suggest is taking the toner cartridge out and tapping it sharply whilst rotating it laterally. Sometimes the toner can cake and not fall down to the developer roller. There is software on the site too.
http://www.support.xerox.com/support/workcentre-5735-5740-5745-5755/documentation/enus.html?operatingSystem=win8x64&fileLanguage=en
Apr 26, 2016 | Xerox Office Equipment & Supplies
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
May 21, 2010 | Xerox Phaser 6180N Laser Printer
Unable to print #10 envelopes on my Xerox WorkCentre 7675... I am using Microsoft Word and selecting the Bypass tray, but I'm still unable to print on these envelopes. Are there any other solutions?
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
Jul 31, 2009 | Xerox Office Equipment & Supplies
Envelope printing
The manual bypass tray on the Phaser 8400 can be set only when you have paper in the tray.
The envelope will read in the set up when you have it in the tray.
Nov 12, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
