I have a coleman gas furnace model#7966A856 ,burner comes on but not fan, it was coming on for a very short while, but then stopped altogether, I hooked up the motor direct and it is working, I have replaced the fan switch, the manual limit switch, and the thermostat, have not replaced the lower limit swithch, could this be the problem?
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
muttandjeff
  • 359 Answers
SOURCE: Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Posted on Dec 17, 2008
Gort007
  • 1187 Answers
SOURCE: COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Posted on Sep 16, 2009
  • 89 Answers
SOURCE: Coleman Presidential II Model 7656A Mobilehome Furnace blower p
have you changed t-stat? if so you need to increase the heat anticipator. if you have a fan limit switch, the setting may need adjusting. Thay will change with age
Posted on Nov 01, 2009
heatman101
  • 43501 Answers
SOURCE: Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 09, 2009
Furance starts, runs short time, blower stops short time, then blower comes on, burner still runniing.
Sounds like you fan limit control is not set properly. Or the blower speed is set to high.
Jan 03, 2014 | Intertherm 56000 Btu Gas Furnace
I have a Coleman AGU10016A Gas Furnace which initially runs fine but after a certain time shuts off and cuts gas to burners and pilot what is the problem?
That's a safety to prevent an unsafe condition. It is caused by any number of protective devices such as flame roll out, blocked flue pipe, fan stopped working and causes the heat exchanger to get too hot and trip the limit switch etc. Call a qualified tech to deal with gas appliances. Gas isn't a DIY thing.
Dec 11, 2013 | Heating & Cooling
Coleman evcon furnace
So the furnace will come on and heat sometimes ? Then other times it will click but not heat ?
Check for fault codes if it has them and make sure it is clean inside burner tubes and clean the flame sensor.
Oct 13, 2013 | Heating & Cooling
My furnace is in a 1994 manufactured home. It is
i think it is your fan because when it is supposed to come on (when hood is hot enough) it won't,...and when the gas valve doesn't get the o.k. from the fan that it is working, the unit will shut it self off so it doesn't over heat. Gas boilers and furnaces have alot of safety things like this,....see if the fan has an oiling place on it. I've seen control panels cause this too,....replace whatever is cheapest first. good luck
Jan 31, 2010 | Tools & Hardware - Others
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Gas burner doesn't work
Gas burners serve as the primary source of heat in a variety of home appliances: water heaters, gas dryers, and gas cooktops and ovens, and-of course-- furnaces and boilers. When the burner fails, most gas appliances are designed to stop working altogether to prevent a gas leak. As a rule, it's best to have gas burner problems fixed by your gas utility service person or a qualified heating technician, but there are a few steps you can take to avoid paying for a service call.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Checking my furnace's ignition
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
