After recently buying a new color ink cartridge, my printer now prints with a pink tone over the image.
  • garydart Jan 27, 2009
    I tried again, removing the cartridge, shaking it vigorously, wiped the ink applying area per your suggestion, and again it printed a pink picture. How should I apply for a replacement cartridge?
  • 29 Answers
Hi
Use a slightly damp paper towel to wipe the cartridge..concentrate on area where ink ooes out..if that does not work-call tech support-your cartridge would be replaced for free..
good luck
Posted on Jan 24, 2009
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Dell 3110cn Printer prints shades of pink
Have you pulled out the imaging drum and transfer roller to see if they are caked in Magenta toner? if so they will need to be cleaned off. Would also suggest blowing out the area around the drum to rid of loose toner in that area.
Feb 15, 2010 | Dell 3110cn Laser Printer
My printer is printing in pink color how can i change it to black
Sounds like your black cartridge is either empty or clogged. Take out the black cartridge and press the print head against a moist paper towel. You should see a nice black rectangle, if you don't you could try placing the print head on a wet paper towel for a few minutes to wick out the ink (ink may seep through the paper towel so beware what surface you do this on). If after this there is still no ink flowing, buy a new cartridge.
Dec 18, 2009 | Office Equipment & Supplies
My Kodak printer stopped printing in color.
Hello sir; Are you using remanufacture ink cartridge? if yes, why don't try brand name cartridge, if still don't work, my suggestion go buy a new machine much save more than send to the shop for repaire.
Nov 28, 2009 | Office Equipment & Supplies
I bought new ink black and color but i try to print in pink and i can't how can i print in pink
Hi alexgallo01
Do you get other colours except pink?
If that is the case,reasons could be:
1. there is not enough RED or BLUE in the cartridge.
2. you haven't selected pink colour on the text or images you are trying to print.
If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
Hope this will help.
If it help you, please give a rating
Cheers
luciana44
Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Can't print BLUE.
I use a clear silicone tube to carefully prime the carts by sucking a dab of ink out of the tiny print holes before installation. I am careful to have a tight seal at the holes to prevent getting too much ink and possibly getting it in my mouth. Make sure each color appears.
Jun 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
My HP CP1700 prints out gray tones in pink.
Your head / nozzles must be dirty , perform a nozzlecheck /head clean from printer software maintainance utility,
regards
Mar 28, 2008 | HP cp1700 Color Inkjet Printer
DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Jan 04, 2008 | HP DeskJet 950c InkJet Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
60 people viewed this question
jasbo
jasbo
