Question about Dell Latitude E6500 Laptop
Screen goes black on my dell latitude e6500 until i press on the screen what is this
  • Dell Master
  • 5,660 Answers
A) Loose connection of Video Cable to back of LCD screen
B) Loose connection of Video cable to screen Inverter
C) Failing screen Inverter
D) Faulty LCD screen
My money is on a bad connection of the Video Cable.
How does this happen Michelebolya?
This is an example of the Video Cable,
http://www.amazon.com/Video-Cable-Latitude-laptop-DC02000HT1L/dp/B0090DV3LS
Click on the photo to enlarge.
The long blue connector to the Left, plugs into the motherboard.
(On the Bottom of the laptop)
It then goes up around the left Hinge, and into the Display Assembly.
[From there the long Yellowish connector on the Right, plugs into the back of the LCD screen.
There is a small cable at bottom, that plugs into one side of the screen Inverter.
Also with this cable, the Wireless Antenna cable is included ]
Just due to normal opening, and closing of the laptop; the Video Cable may become pinched.
This can cause the cable to be pulled on, and loose connections can result.
And/or damage to the Video Cable can result.
Stretched/Broken tiny wires inside the Video Cable.
Suggested method of repair;
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Remove the bottom of the Base Enclosure.
(Bottom Cover.
Dell? -> Base Assembly)
http://support.dell.com/support/edocs/systems/late6500/en/sm/html/base.htm#wp1184372
Dell Support > Latitude E6500 Notebook PC > Service Manual > Display > Removing the Display Assembly,
http://support.dell.com/support/edocs/systems/late6500/en/sm/html/display.htm#wp1179842
This is a BOTTOM view.
The Video Cable is shown on the Right.
Looking at a Top view the Video Cable is on the Left.
BEFORE you touch ANYTHING, micheleboyla, you need to be wearing an ESD wrist strap.
Electro Static Discharge.
Average cost ranges from $3 to $6.
This is one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a laptop.
With wearing an ESD wrist strap, and having it's alligator clip attached to a good ground source, your laptop is safe from Static electricity.
Once you have the bottom cover off, the most sensitive hardware component to Static shock; is exposed.
The Processor
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
(I feel an Anti-Static Mat is unwarranted, and I don't want my wrist connected to the local utility companies ground source)
You can set a large metal serving tray, (Unpainted), on the table you're working on, and connect to it.
Or perhaps a large metal knickknack. (Unpainted)
Connections CANNOT just be visually inspected. You have to Physically see if you can plug the plug in tighter.
First motherboard side.
No? Go on.
Open the Display Assembly.
The plastic frame in front of the LCD screen is the Display Bezel.
From what I can see the Display Assembly does Not need to be removed, in order to remove the Display Bezel.
http://support.dell.com/support/edocs/systems/late6500/en/sm/html/display.htm#wp1201557
This means you can pop the Display Bezel off, and have access to the Video Cable small cable, to the screen Inverter. See if this connection is loose.
No? Didn't change anything after you tried plugging it in tighter?
Go on.
The LCD screen is an assembly. It is composed of layers, and held together in a factory set specific pattern; by a metal Screen Frame.
[Screen Frame also resembles a picture frame ]
Screen Frame screws to the Display Cover, (Top cover of laptop when closed),
http://support.dell.com/support/edocs/systems/late6500/en/sm/html/display.htm#wp1202034
This means you may be able to lean the top if the LCD screen/Screen Frame forward, and be able to access the Video Cable connection of the LCD screen.
Won't have to remove Display Assembly to access, and after checking cable connection for tightness, can prop LCD screen against Display Cover, and see if that repaired it; before reassembling laptop.
One example,
http://www.insidemylaptop.com/replace-cracked-screen-dell-inspiron-14z-laptop/
See where he's got the LCD screen tilted in Step 6 photo?
No? Not enough tilt, to access LCD screen connection of Video Cable?
Will the LCD screen lay down as shown in Step 7 photo?
W-A-T-C-H the Video Cable's length. May NOT be able to do this.
If Video Cable connects at the Middle of the LCD screen,
this may = No.
In that case ease the LCD screen forward, and rest on Palm Rest Cover above Keyboard. Watch the length of the Video Cable. See if you can plug Video Cable in tighter, to the back of the LCD screen.
Still no?
Then you need to perform a continuity test on the Video Cable.
Multimeter set to OHM's (1K), and check every wire in the Video Cable.
Also have an assistant gently wiggle the cable, and see if you get an intermittent reading on the multimeter. Indicates broken wire. Replace.
OR,
Take the Video Cable down to the nearest small computer repair shop, and have the resident tech check it for continuity. Should only be a couple of bucks.
Video Cable good?
Go on.
Next in line is the screen Inverter.
However to test a screen Inverter requires a sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to;
A) The above,
B) Ease of access, (Just pop the Display Bezel off),
C) Low cost
Most just replace it. One example,
http://www.parts-people.com/index.php?action=item&id=5896
OUCH!
Let's try that again,
http://www.ebay.com/itm/Dell-Latitude-E6500-LCD-Inverter-Board-H024P-/130819120437?pt=LH_DefaultDomain_0&hash=item1e756d5d35
Still no?
Then the problem is the LCD screen.
Replace
Seem like a bit of trouble?
Better to re-connect a Video Cable, or buy one, or a screen Inverter; than replace an LCD screen, and find that wasn't the problem at all.
http://www.laptopreplacementscreen.com/dell-laptop-replacement-lcd-screen/dell-latitude-e6500-replacement-lcd-led-screen-15-4-laptop-screen-hd-wxga/
For additional questions please post in a Comment.
Regards,
joecoolvette
[The Display Bezel is made of a space-age plastic, usually. Pretty tough stuff.
However it CAN be broken.
The Display Bezel has Tabs on it, surrounding the inside perimeter.
These snap into matching Latches, on the Display Cover.
The thick guitar pick to start with, is an excellent method.
However somewhere in there, you're going to have to slip a fingertip under the Display Bezel; and your fingernails will be against the LCD screen.
This = No
I lay the Display Assembly back as far as I can.
I then suggest you cut a piece of cereal box; or thick construction paper, or etc; to fit as close as you can, to the inside edges of the Display Bezel.
Protects the LCD screen from your fingernails.
The INSIDE edge of the Display Bezel, on the Right side/Middle; is flexed up first.
Can't get a fingernail under the inside edge?
Move over a little. You are at a Tab/Latch.
Pop one Tab/Latch loose, move over going DOWN the Right side.
Snap! Almost sounds like you are breaking something.
(DO support that small area of the Display Bezel, on BOTH sides, though; when popping it loose!)
Go around the Bottom, and come up the Left side.
Snap, snap, snap...................
By the time you get most of the way, the Display Bezel should pop loose.
Line the Tabs/Latches back up, and snap them into place, one by one; when reinstalling the Display Bezel ]
Posted on Jan 15, 2013
  • 324 Answers
SOURCE: Dell Latitude D620 - Screen shows boot up, but then goes blank
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Hope this helps and have a super day!
Ron
Posted on Dec 15, 2008
veenu goel
  • 38 Answers
SOURCE: how can I turn on wifi led on dell latitude e6500
hold function key and press wifi key on ur lappy keypad
Posted on Nov 07, 2009
SOURCE: web cam on latitude e6500
I have same problem. I downloaded the latest webcam driver, installed it. Everything is fine, in the device manager the device are present. But when i try to load the webcam application from dell the device is not present or not installed appear.
Notice: if I try the YM webcam, the device work properly - that's mean the device driver is OK.
So the E6500 is a beautiful great notebook, with poor software.
Posted on Nov 25, 2009
bob_computer
  • 3153 Answers
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Mar 15, 2010
  • 19 Answers
SOURCE: How can I turn on wifi on dell latitude e6500
It's a small button on the right. See http://support.dell.com/support/edocs/systems/late6500/en/sqrg/pdf/U084C0MR.pdf page 7 and 8
Posted on Sep 29, 2010
How do I unlock the number key on my E6500 latitude keyboard
Hi Tiffany,
Found this after googling .....
Here is how you enable the number lock feature:
1) While booting up press F2 repeatedly
2) After the Dell logo appears, you will be diverted to a Settings menu
3) Expand "POST behavior"
4) Select "Keypad (Embedded)"
5) Press the "By Num Lock" button
6)Press "Apply"
7)Press "Exit"
Nov 18, 2014 | Dell Latitude E6500 Laptop
Where is the wifi key on E6500 latitude
You may refer to the user manual mentioned below to turn ON the wireless switch for your Dell Latitude E6500:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-e6500_setup%20guide_en-us.pdf
Page: 13 and 16
Hope this helps..
May 16, 2014 | Dell Latitude E6500 Laptop
Ush driver/touch senser
Andrew,
At the link below are the Latitude E6500 Drivers Downloads. Click the link below, choose your OS and then the drivers you need to download.
Latitude E6500 Drivers Download Page http://dell.to/1lDFBKO
Thank You,
Dell-Jesse
Dell Social Media and Communities
Mar 13, 2014 | Dell Latitude E6500 Laptop
Just replaced my dell laptop e6500 lcd screen but the screen comesup white grey then turns black with no booking up on screen.
check connections to the inverter, check inverter wires not damaged ( the ones that run to the screen bottom). Check cable to screen rear is tight and then check cable to motherboard is tight.
if no luck, suspect faulty inverter, or screen cable or... if the screen was not new, incompatible or damaged screen
Jan 26, 2011 | Dell Latitude E6500 Laptop
Hey there I own a Dell Latitude E6500 running windows 7 64bit. my laptop was running fine until i pushed restart, the computer boots but comes up to a screen like the NTLDR is compressed but this message...
was boot to the recovery cd for 7 and run the collowing commands from the command prompt. (Press key after each line)
c: cd \windows cd system32 compact /u c:\ compact /u c:\*.* x: bootrec /FixMbr bootrec /fixboot bootrec /rebuildbcd
with that the boot loader was flagged to no longer be compressed (Prevent re-occurance), uncompressed (Make it usable), and then rebuilt.
Nov 22, 2010 | Dell Latitude E6500 Laptop
How can I turn on wifi led on dell latitude e6500
Nov 07, 2009 | Dell Latitude E6500 Laptop
Dell Latitude E6500 Laptop Logo
579 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
