Question about Canon PowerShot SX100 IS Digital Camera
External mic wont work
I have a lapel mic that i want to use to record videos and have a decent sounding mic. instead of the built in mic. the camera has a 3.5 mm a/v/ out jack. im not sure what to do or what options to enable/disable
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The A/V out jack is for output from the camera, not input to the camera. The camera has no way to accept sound from another device. You can record onto another device and then combine the soundtracks using video editing software on a computer, or even completely replace the camera's audio track. However this has to be done on a computer, not in the camera.
Posted on Jan 15, 2013
How to disable Dell latitude E5500 built in mic so you can connect an external mic?
Just plugging in the external mike into the jack should AUTOMATICALLY disconnect the internal mike.
May 27, 2014 | Audio Players & Recorders
MY VIDOE CAMCORDER WILL NOT RECORD SOUND WHEN I ATTACH A MIC
You need to connect your mic to an amplifier first and then to camera. Orherwise mic has not enouth power output. Zoom h4n might work but its expansive. Or u can buy wm-v1, wireless mic, it'll work just fine. Or buy mic with power already built in, like Rode VideoMic.
Apr 12, 2012 | Canon VIXIA HF R20 Camcorder
When i plug in a mic, it wont work. under
You need to do the following
1. Open Sound & autido devices from controlpanel
2. Click Advanced button in Volume tab
3. Select properties from Options menu
4. Select Recording & press ok
5. Select External MIC instead of others
Aug 02, 2009 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
I dont understand how to use an external mic. Use of external mic.
Your external mic needs to have a 1/8" plug. You will need to find the "Mic" input, this is generally found behind a removable or hinged plastic or rubber panel, and usually near the A/V plug connectors. When you plug in an external mic, the camera switches over to use it rather than the built-in mic. On this camcorder, you cannot set the recording level of the external mic. The camera sets the level automatically. So it is simply a plug-and-play, or plug-and-record solution.
Using an external mic allows you to reduce self-noise and handling noise. It is generally recommended for better videos. Different microphones are likely to interact in different ways with your camera and its automatic level-setting, so you should try out different microphones if you have more than one available to you.
Sep 26, 2008 | JVC GZ-MG575 Camcorder
MV630I
the best is to have a mic plug in on a camcorder its more advantage than using a mic built in. hope that helps you
CHARCOIS
Jul 23, 2008 | Canon MV630i Mini DV Digital Camcorder
Microphone
DCR-HC36 doesn't have External Mic option. Sound can be recorded only with built-in mic.
May 30, 2008 | Sony Handycam DCR-HC36 Mini DV Digital...
Missing Audio
sound changes to external mic. when any ex. mic. is inserted the internal mic. comes out of order then you don't and can't have two sounds same time that mean you only get the ex. mic sound regards please don't forget to rate thx
May 02, 2007 | Canon MV630i Mini DV Digital Camcorder
Built-in microphone does seem to work
The only way to really tell if the buit in mic. is bad is to replace the mic or plug another one in the external mic. jack. Also use the input (red and white) RCA jacks and input a signal from a stereo or TV into it and record. If still no sound then its probably Bad capacitors in the sound processor Printed Circuit board. Sorry to be the bearer of bad news but mostly all of older camcorders suffer from this breakdown fault. Good luck
May 21, 2006 | Panasonic Palmcorder PV-GS15 Mini DV...
Canon PowerShot SX100 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
