Question about Home Security
Rodgers wall thermostat operates air but can not set heat temp
Numbers constantly climbing up to 99 but fan is not coming on when on heat setting. House does appear to be very warm.
    New Friend:
    Problem Solver:
  • 6 Answers
You might need to replace your thermostat
Posted on Jan 15, 2013
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
szanti
  • 36 Answers
SOURCE: How do I delete the program settings on my
Go to this web site.
Please let me know if this helped.
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6175.pdf
Posted on Dec 06, 2009
liteswink
  • 99 Answers
SOURCE: I have the thermostat set for 70 degrees on the
Based on your explanation this is an erratic operation of the thermostat, first thing that you need to check is the wiring make sure that all the wires are proper looped on the under terminals then reset the thermostat if the problem still persist I think you need to replace the thermostat. If you need further support call the homeowner techline 18002842925.
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: We have the white and rodgers thermostat model
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Posted on Jun 28, 2010
SOURCE: The thermostat is a White-Rodgers 1F82-261.
The display on my thermostat is locked on 72 degrees. When I turn the switch from a/c to the off position, it appears that the heat comes on.
Posted on Jul 27, 2010
Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
Mar 21, 2017 | Coleman Heating & Cooling
What is difference between on an auto on thermostate
I'm not sure exactly how this applies specifically in a car, but on a home heating and cooling (air conditioning) thermostat, it is often associated with the fan or blower setting.
If for a system fan:
"Auto On" setting in a heating / cooling system would start the fan when the temperature climbed above or dropped below the setting you on the thermostat and start the heat or cooling source. Once the thermometer indicates the desired temperature had been reached, the heating / cooling source would be stopped and the fan would turn off.
"On" would run the fan all the time, regardless if the thermostat tired to start the heat or cooling source. This would result in constant circulation of the air in the space(s) and tend to keep warm or cool spots (rooms) from being created.
Nov 30, 2015 | Cars & Trucks
Furnace blower runs after temp is reached
Is your tstat fan selector in auto?? Does the fan ever shut off?
Jul 18, 2017 | Heating & Cooling
I don't want to program the 1f85-275 thermostat, i will adjust when needed
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To manually operate the unit just set the thermostat to heat mode and the fan to auto. Press the hold button one time then set you desired temperature.
Nov 15, 2012 | White Rodgers White-Rodgers 1F85RF-275...
I have a white-rodgers type #1F86-241 thermostat. Not sure if my problem is thermostat or not but this is what I have. currently have two zones first floor and second floor. Second floor is problem. I...
From what you're saying I would reccomend that you start with a new thermostat. I think that will take care of your problem, but I've always started troubleshooting by doing the easiest and least expensive first. Hope this help. Thanks
Nov 21, 2010 | Heating & Cooling
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
The thermostat is a White-Rodgers 1F82-261. We have the very same thermostat on both the upstairs and downstairs systems. Both thermostats have all settings set exactly alike. The upstairs system has...
Steps that you need to do.
First is to reset the unit by pressing the reset button for two seconds right below the fan switch.
Second is to re- program the thermostat correctly, make sure that the unit work fine when the thermostat has been bypass.
Then monitor the thermostat operation, I think this will resolved the problem. If you need further assistance call this number 18002842925.
I have attached the link of the MANUAL
Jun 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Heat will not come on.
No heat troubleshooting
Diagnostic: Set SYSTEM Switch to HEAT and raise the setpoint above room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation listed above. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a HVAC service
person to verify the heating is operating correctly.
If you need further support call the techline 18002842925.
Nov 16, 2009 | Honeywell Electronic Programmable...
Home Security Logo
29 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
