KELVINATOR AIR CON
HI IT ONLY WORKS IF I SWITCH IT TO "FORCED OPERATIONS" BUT DOESN'T WORK IF I SWITCH IT TO "AUTO" OR REMOTE CONTROL". REMOTE CONTROL IS FINE.IT WORKS WITH ANOTHER AIR CON.DO YOU THINK ITS THE REMOTE CONTROL SENSOR? OR SOMETHING ELSE.
  • 400 Answers
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Posted on Mar 05, 2009
The mode button on my kelvinator remote 6711A20012M is not working and won't change to heat yet all other buttons are working on the remote pls help???
try resetting the remote the rest switch is under the flip cover of the front of the remote use a tooth pick or something that will fit if that dose not work reset the air con by turning isolator or circuit breaker or mains breaker of for ten sec if still not working you may have to replace your remote with a universal remote can be purchased on eBay or refrigeration suppler near you good luck let me know how you go
Jul 15, 2014 | Heating & Cooling
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
Need to change from cooling to heating for a Kelvinator KSR27G split sys air con. Have tried ourselves using the remote, but we feel it is not operating correctly. No manual came with it when we purchased...
The cooling symbol on the remote is generally an "icicle" , the heating is a symbol of a blazing sun. Make sure you have selected the right mode. Also check the filters... if they are dirty, you wont get decent heating from any air con.. cheers,
BTW, I believe that electrolux have a site you can download instruction books.
Jul 14, 2011 | Heating & Cooling
I have an old Kelvinator air conditioning. Not sure what the model is since I have lost the manual, but from the remote control I can see some code looking like the model number: 6711A20012M. A few weeks...
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
Dec 25, 2010 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Lg airconditoner remote contol n98
Open the front grill of the indoor unit. Check on right hand side for a forced operation switch. This switch is for selecting of either manual operation or remote or auto, select remote, then try. You can also press the reset button on the remote, under the cover with a pen. Hope this helps
Oct 09, 2007 | Network Computing Devices NC900 Network...
Heating & Cooling Logo
501 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
