Question about Sony Playstation 3 (PS3) Console
Ps3 toshiba hdd2h83 corrupted - Sony Playstation 3 (PS3) Console
My ps3 hard disk file is corrupted
jaynitz
If you are getting the corrupted drive message this means that you have corrupted data on your PS3's hard drive. The link below will help help you address this issue.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 31, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: PS3 KEEP SAY DISK FILE SYSTEM IS CORRUPTED WHAT TO...
Guest
If you are gettting the corrupted drive message this means that you have corrupted data on your hard drive. The link below will help you address this. If you still have trouble then most likely you will need to replace the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Issken
May 16, 2010 | Sony Playstation 3 (PS3) Console
Corrupted data
It's possible that you're turning off the ps3 while it's saving, corrupting the save data.
Make sure when you turn off the ps3 it's not in the process of saving.
Try the above and if you still have no luck it's possible there's an issue with your ps3's hard drive, have you had any problems with any other games?
Also, if the problem persists, try deleting the MW2 gamedata, located under gamedata on the ps3's menu.
Best of luck to you.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
PS3 file corruption fix!
He's right, this really will work
Feb 24, 2010 | Sony Playstation 3 (PS3) Console
DATA CORRUPTION ON PS3 CODE 80029209
cwsgds
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
Issken
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
PS3 HARD DISC CORRUPTED
i wonder if u have changed the ps3 hard disk or it's the original toshiba hard disk that comes in the ps3 ??
so if it's a new one u may haven't connected it right
n if it's the original one u can check on it by removing the plastic part at the bottom of the ps3 n try to check on it
Aug 24, 2008 | Sony Playstation 3 (PS3) Console
Corrupted hard drive
All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
Aug 10, 2008 | Sony Playstation 3 (PS3) Console
Ps3 system update data corrupted
Hook up the external to your USB port and copy everything over. I had to do that when I installed a larger hard drive in my PS3
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
File system hard disc corrupted
the better choice is...
buy a new hd and replace it, the original go bad quick.
replacing it resolve all of corrupt problems.
sometimes, you repair it,then when going to save a game, the ps3 freezes.
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
