Question about Toshiba Satellite 1805-S204 Notebook
Dvd/cd bad on toshiba 1805-s204. What dvd/cd burners can replace
The computer is older so don't want to spend hundreds of dollars but is good shape and would like to use. I want an internal drive for portability as well as the usb is not 2.0.
My Toshiba Satellite 1805-S204 turns off when i'm trying to open DVD-ROM bay. Sometimes i can open it but than notebook turns off when i'm closing DVD-ROM bay. I want to disassemble 1805-S204 to find out...
I suspect, if you haven't got it working on the AC adaptor when this happens, that maybe the battery is low power. If it does it when the AC adaptor is being used then I think you are right, the DVD ROM is faulty.
Remove the battery and AC adaptor.
Remove the Memory cover.
There is a singel screw that holds the DVD drive bay in. Remove the screw and pull the drive out.
Replace the drive with and IDENTICAL model and that should be that.
Hope this helps.
Nov 06, 2010 | Toshiba Satellite 1805-S204 Notebook
Hik. I have lost my cd drive from my satellite 1805-s204. how can i obtain the drivers?
download drivers from toshiba website, please follow the link below
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp
Oct 10, 2010 | Toshiba Satellite 1805-S204 Notebook
Can a wireless card be installed into a Toshiba Satellite 1805-s204?
You can install a PCMCIA wireless card or a USB wireless device.
Jan 26, 2010 | Toshiba Satellite 1805-S204 Notebook
Toshiba 1805-S204 Recovery
Go to the start button and click on run> type cmd in the text box> type format C: /Q /fs:ntfs then hit enter...this will perform a quick format,wipe the drive and format to the ntfs file system. Now your ready for a fresh install of whatever floats your boat. Make sure you type it exactly and with the correct spacing.
Aug 26, 2009 | Toshiba Satellite 1805-S204 Notebook
Toshiba satellite 1805 s204 "media test failure, check cable"....
Did you install the windows system etc? If not boot from the system restore cd and it should work. If it will not boot from the cd-rom then more damage was done then was apparent and the unit would require factory qualified repair. Be sure of the cost before committing to repair since on laptops sometimes it is cheaper to replace the repair. Good Luck
Jul 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Cd for Toshiba Satellite 1805
ok..when turning it on..hold down F2. to go to set up..and see if that new drive is activated..be careful in there..there are loads of things that can go haywire.
Oct 16, 2008 | Toshiba Satellite 1805-S204 Notebook
Toshiba sat. 1805-S254
I am currently using the laptop model that you described. Go to toshiba support, click download, click portables, click satellite, and where it says: choose model, click show older models. Type in your satellite model on the search bar, (1805-S254) and click 1805-S254 in the results and hit GO. Now, the second thing from the top of the list of drivers says: BIOS. click the plus. Find: ACPI Flash BIOS version 1.10 for Satellite 1800/1805-S204/254/274 (v1.10; 10-23-2001; 671K)
and click it. Download the file and run it. Now follow the directions to make a BIOS floppy disk. After the disk is created, restart the computer. When the screen that says: Toshiba comes on, hit F12 to boot from a different device. Then it gives you a bunch of options. Hit the letter on the keyboard that tells the computer to boot from floppy disk. Then it should erase your current bios and rewrite the old one in. DO NOT update the BIOS! In the new BIOS, toshiba has a file that DOWNCLOCKS your processor. This is what makes your computer run so slow. Now people have complained that computer has overheated and shutdown but since i've downgraded the BIOS, it's been running just fine! Hope this helps! If it doesn't, email me at: fneoh7832@live.com.
Feb 13, 2008 | Toshiba Satellite 1805-S204 Notebook
Step to how to replce cmos battery toshiba 1805-s254
Hi!
If you already found the cmos battery, then try to check its "rating" and size to accomodate inside the board. After that fix it as it should be.
Dec 13, 2007 | Toshiba Satellite 1805-S204 Notebook
Toshiba Satellite 1805-S204 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
