Question about Brother PC302RF Refill Kit
Instructions replace film in brother pc302rf - Brother PC302RF Refill Kit
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
How to send a fax
Hi kerrihille,
Follow these Image Instruction:
In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Aug 03, 2012 | Brother PCIF FILM FAX580MC - LE0542001
How to change the film fuser
Please refer video "How to replace fuser Sleev"
Similar to HP fuser film replacement you can replace Brother HL4040CN
Feb 18, 2012 | Brother HL4040CN Laser Printer
I have a Brother MFC-7340 and recently replace the toner and now the background is dirty looking when I print, ie grey where it should be white! What can I do to clean it up? Thanks!!
Either you purchased a a bad quality remanufactured toner cartridge or your fuser film is damaged.
If there is some kind of debris in black color that is on printouts, your fuser film might be damaged. Have a printer technician replace it.
If there is no debris, only bad quality printouts, it's the toner cartridge that needs replacement.
Mar 05, 2011 | Brother MFC-7340 All-In-One Laser Printer
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
New film in Brother 885-now paper and fil jam
2 reasons.
1.You have not installed the film in correct manner
2.Your film is not geuine brother film.
Jul 30, 2010 | Brother IntelliFAX 885MC Plain Paper...
I have a brother 575 and when i would make copies, the film would come out attached to the paper that was copied. well. I opened it up and one of the wheels fell out of somewhere. I can not figure out...
Search inside the machine by opening the latch on the right side. Be sure to unplug, as it may be hot. Pull out the film cartridge and look for the missing wheel. Remove and order a replacement cartridge. Shop because prices vary greatly. You can order replacement film rolls or the entire cartridge. In your case, i would go for the entire cartridge. You can find them for under $15.
May 05, 2009 | Brother FAX-575 Plain Paper Thermal
I have a Brother Fax-575 that needs ribbon replaced. Can I use a compatible brand which indicates that it meets mfg OEM standards or should I stick with Genuine Brother?
A compatible should be fine. Some of the new Brother laser machines can actually be broken by non-OEM toners, but yours is not a laser. The worst I'd expect from a donor film might be a slightly poorer image. Try it out. If you have to load the film rolls into your old cartridge, make sure it's running the right direction, and with the correct side down.
Feb 26, 2009 | Brother FAX-575 Plain Paper Thermal
Useing PC 102rf brothe ribbon film in a brother fax 575
I was told it no can do, or be done- whatever! I am not finished yet, that is a challenge!!
Jan 15, 2009 | Office Equipment & Supplies
Brother laser printer printout
You need to clean your drum unit:
see http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001044&Sympt=The+print+jobs+have+black+spots+or+black+dots.+How+can+I+improve+the+print+quality%3f&Model=3&ProductGroup=1&Keyword=dot&ProductID=HL2040
Worked for me!!
Dec 19, 2007 | Office Equipment & Supplies
Brother PC302RF Refill Kit Logo
27 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
