Question about GE Amx 4 Plus Mobile X-ray Unit Model 46-270954g1
GE OEC portable x-ray unit trips the breaker while driving
Intermittentlt the breeaker trips while driving.
4 Suggested Answers
Number5Gayle
  • 98 Answers
SOURCE: GE DVLR223 dryer wont start....breaker is not tripped
check all the connections on the back of the dryer, if a few screws are loose, that could be the problem.....now the other thing....it might need a new motor. Unplug it before checking it out!!
Clean out your vent hose and the outside of the Vent to prevent fires.
Posted on Jul 31, 2009
  • 7 Answers
SOURCE: The breaker is tripped.
Turn off the power and check for bad or loose connection where your
GE Stove Top plugs in.
Posted on Aug 04, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE jvm187osf02 microwave loses power
It may be a blown fuse or the thermal cutout (T.C.O.) or thermostat on the magnetron or on top of the oven cavity.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 20, 2009
Float switch on my Dishwasher broke and no water was flowing into unit.Replaced with GE replacement switch, but trips the breaker.Old switch doesn't trip..but doesn't work.
I would suggest checking the wire placement on the new unit as for the breaker to trip indicates that the power wire is connected to a ground point and shorting out
Talk with the service agent as to a correct connect schematics for the part
Jan 20, 2016 | GE Dishwashers
Trips when plugged in
What trips? If you are referring to the circuit breaker then I suspect the breaker is not sufficient for the power the unit draws. Beware installing a higher amperage breaker. First be sure the wiring and all bomponents are adequate.
May 21, 2015 | GE Zoneline In Wall Ptac Unit Air...
Keeps tripping the breaker
You have an opencircuit possibly at the wall outlet. Shut off breeaker, pull off outlet cover and take out plug unit. Check to see all wires are secure and no indication of burning or melting. Any black marks indicate an arc of electricity has occured. If suspicious, replace plug with new one.
Apr 21, 2013 | Heating & Cooling
I just purchased a souleus 12000 btu portable air conditioner. The unit works fine but keeps tripping the circuit breaker in my apartment. What causes this and can it be fixed or is it just the wiring in...
First, you need to determine what, besides the Souleus, is on that electrical circuit, and whether the circuit is 15 or 20 amp.
12,000 BTU A/C's tend to pull 10-12 amps, and they can peak just under 15 when the compressor starts. So a new, right off the shelf unit will max out a 15amp circuit. An older model with a worn out starting cap will demand even more amps at compresser startup.
Aug 14, 2010 | GE APN08AA Portable Air Conditioner
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Friedrich model 24m continually trips circuit breaker. had new 220 line installed and have replaced breaker but problem continues.
How new is unit? Looks like a portable. if it has a 3 prong plug, it sounds like the compressor is shorted to ground, tripping breaker. If its new, return it, if not, junk it
Aug 05, 2009 | Friedrich P-12 Air Conditioner
Aug 04, 2009 | GE Kitchen Ranges
My GE ductless system is not heating properly and trips breaker
Call them yourself. Let them know your compressor is tripping your breakers. Also, ask how to obtain parts for your system. It's rediculous an hvac tech cannot get advise from ge.
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
GE Amx 4 Plus Mobile X-ray Unit Model 46-270954g1 Logo
54 people viewed this question
Top GE Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a GE Science and Laboratory Expert? Answer questions, earn points and help others
