Question about Planet Audio P9745B / P9740 Car Video Player
My Planet Audio P9740 Bluetooth is asking for a Code/Pin
Dont have pin code for bluetooth on a (planet audio 9745b)! Can it be reset? and how?!
Try '0000' or '1234' (without the quotes) or look it up in the set up guide that came with the Bluetooth device.
Jan 03, 2015 | Radio Communications
How can i get rid of the blue screen that says cant play while driving on my planet audio p9740 monitor DVD
Connect the Parking brake wire to a ground source; either permanent chassis or with a toggle switch.
Mar 04, 2013 | Car Audio & Video
How to display clock on a planet audio p9745b
bummer - cant find any manuals online about this receiver. Maybe hold down the volume down and see if the option becomes available?
Jan 03, 2013 | Planet Audio P9745B / P9740 Car Video...
Planet audio p9740 user's manual
how do I transfer my pic off my digital camera sd card into my p9740 I put the card inside it read it but I can't program the pic to choose one as my screen saver...do u have a solution?
Mar 13, 2012 | Planet Audio P9745B / P9740 Car Video...
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
I was hooking my Planet Audio P9745B up in my 2000 Honda Accord and it said Warning Video something so it wouldn't show but you could hear the movie and then it showed up on the screen. So i put everything...
Sounds like there could be a shorted wire possibly power but what sounds like happened is the unit grounded out and blew the cigarette lighter fuse. Check fuse box for blown fuse, if this is the case I would suggest pulling radio out and having the wire harness for the radio professionally connected and inspect all connections
Aug 23, 2017 | Planet Audio P9745B / P9740 Car Video...
Pioneer Bluetooth
The Code to activate it is 83423
Jan 12, 2008 | Car Audio & Video
Planet Audio P9745B / P9740 Car Video Player Logo
402 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
