Question about Cross Sentinel 10 Sheet Cut Shredder
Shredder is jammed it is a sentinel mx80b - Cross Sentinel 10 Sheet Cut Shredder
Sentinel Pro On Guard shredder just stopped working
Mechanism could be clogged with debris, causing motor overload and thermal shutdown.
Dec 13, 2016 | Shredder Office Equipment & Supplies
Unclog a jammed paper shredder model MX80B ?
If reversing the shredder doesn't work, Unplug the power connection and look at the under side of the cutters and pull out all the paper.
Hope this helps.
Feb 21, 2015 | Shredder Office Equipment & Supplies
Brand new and will not start,
Make sure the top of the shredder is sitting on the bottom part correctly. There is a safety switch underneath the top that needs to match up with the piece on the bottom bucket, otherwise it will not allow the machine to turn on.
Nov 23, 2013 | Intek America Inc Sentinel 6-Sheet...
Sentinel Paper Shredder
Warranty if new no problem.
Aug 21, 2013 | Office Equipment & Supplies
I have a Sentinel M120. Can I have the company's website so I can diagnose problem or should I ask you.
You should "Google" the company to find it. That is what I would have to do.
If you had asked the question or outlined the problem, I would have tried to help you.
With consumer grade shredders, the answer is usually replace the shredder.
Thanks for your question @ FixYa.com
Feb 06, 2011 | Office Equipment & Supplies
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
My shreder does not work, it is not jamed, it is pluged in, the green light is not on, and it does nothing.
After unplugging my shredder, I turned it upside down and in the area of the shredder mechanism there is a slot that has a little red lever in it. I moved it and tired again and the light came on and the shredder worked. I think it is like a circuit breaker -- we have been having lots of lightning storms and my shredder is not on a surge suppressor.
Feb 20, 2010 | Cross Sentinel 10 Sheet Cut Shredder
Shredder
Remove as much of the jam as possible then saturate any paper left with shredder oil or you may use any liquid vegetable based cooking oil from your kitchen. After letting paper soak for at least 7hours you should be able to power through the jam. If not call Fellowes customer service at 1-800-945-4545
Nov 27, 2007 | Office Equipment & Supplies
64 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
