Question about Neff W5340X0 Washer
Flashing F12 on display
My Neff W5340x0 washing machine has stopped working and keeps flashing F12 on the display - any ideas on what the problem might be?
F12 is either the motor, or eprom chip on pcb. Most likely to be motor
Posted on Jul 11, 2007
SOURCE:
F13 error code
Try unplugging the machine for a few hours to rest the code on the board.
Oct 14, 2013 | Neff W5340X0 Washer
Neff washing machine made beeping noise and
if it is shorting you need to get a service tech in . with its lights blinking it normally means a mains fault that can only really be fixed by a pro
hope this helps
take care
May 15, 2010 | Neff W5340X0 Washer
My neff washer has error code f 18 on it
The F18 Error Means that you need to do the following
Nov 07, 2009 | Neff W5340X0 Washer
Neff washer dryer V5360XOGB red led light keeps going round
THIS IS A POWER MODULE FAULT IT WILL NEED REPLACING IT SITS AT THE FRONT LOWER RIGHT HAND SIDE THEY ARE NOT CHEAP.... SORRY
Aug 09, 2009 | Neff W5340X0 Washer
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Jan 18, 2009 | Neff W5340X0 Washer
DI 'My self' Washing Machine Door Rubber
This video will show you how to change the door seal gasket on your neff washing machine Neff W5340X0
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Neff W5340X0 Washer
Need instruction book for neff washer w5320x0
NEFF WEBSITE HAS PDF FREE DOWNLOADABLE VERSIONS ON THERE WEB SITE.
Jan 12, 2009 | Neff W5340X0 Washer
Neff washing machine W5320
What is the temp of the water coming in to the unit. If it is not hot enough some machines heat the water up to a prescribed temp before washing, rinsing etc..... Could be a problem with the sensor too...let me know,
Feb 10, 2008 | Neff W5340X0 Washer
Neff W5340X0 Washer Logo
707 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
