Question about Back to Basics Smoothie Elite Work Top Blender
Ca4204 need blade assembly
I have a vitamix 5000 unit. Blade assy makes noice ; is loose. Where can I buy the set of bearings for the blade assembly?
You will need to source them from a bearing supply company as Vitamix only supply the bearings as a complete unit with the blade assembled. Once you have the bearings out take the sample with you to the bearing supply company for correct identification.
Jun 27, 2017 | Vitamix Blenders
Need a blade assembly for Black & Decker Blender Model No. BL2010BGC
Fixya does not sell replacement blade assemblies. Check with a local appliance parts supplier.
Oct 26, 2016 | Blenders
In the base, when I put the food in the cup, and the blade cup in doesn't fit the base. it appears the the blade doesn't go down in the base. I need help, I don't know if the base
Lots of questions, not a lot of information. Is the rubber sealing washer in the wrong place. I have no idea what model/brand you have but on most blenders the rubber seal will go between the beaker and blade assembly, not the blade assembly and the collar.
Jun 18, 2015 | Blenders
How to lubricate blade assembly.
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
How do I replace the knife unit in a krups type 243 blender?
Take the blade assembly out of the jug, hold the blades with a towel and turn the driving clutch on the other end. Whichever way the motor turns those blades when operating, you need to turn the drive the opposite way to undo it. If the nut is seized up and wrecks the drive the parts list shows all parts as being available EXCEPT the white bearing housing AND the complete assembled blade and housing.
May 16, 2014 | Blenders
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Amazon com vitamix wrench assembly Home Kitchen
Jan 30, 2014 | Vitamix Blenders
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
I need the Jenn-Air Blender blade assembly too. Anyone sell me one?
Hello, Do you still need the jenn-air blade assembly? I have one to sell. Do you need the collar also?
Jun 28, 2009 | Jenn-Air JBL800 Work Top Blender
Back to Basics Smoothie Elite Work Top Blender Logo
83 people viewed this question
Top Back to Basics Blenders Experts
Mike
ray gallant
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
