Question about Technics SL-DZ1200 Turntable
SLDZ Platter heavy or sticking.
My SLDZ platter is not allowing me to easily manipulate it. It feels very heavy and makes it very hard to mix.
djproaudio
  • 515 Answers
SOURCE: High-pitched, repetitive squeaking noise from under platter on 1210MK2
Make sure there is nothing on the magnet part of the platter. Also, sometimes, the screws that hold down the plastic protective cover underneath the platter might not be seated all the way. Lastly, look at the bottom of the magnet, and make sure that it is in tact, and nothing is bent, broken, or cracked.
Other than that, try switching out the platters from your other turntable, and see if the problem persists. You need to rule out what it is not, before you can proceed with finding out what is the problem. So if the noise moves to the other turntable, you know the issue is with the platter. If the noise remains on the same turntable, then you can rule out the platter being the culprit, and can isolate the issue to the turntable. I've never heard of this, and I've fixed well over 3000 Technics 1200MK2/MK3/MK5 turntables in the past 10 years. I am also considered THE 1200s MASTER. So, I am not sure what could be causing this noise, other than some foreign matter. If your in the NY metro area, bring it on by, and I'll take a look at it, or give us a call, and I'll try and refer someone locally for you:
http://www.tweakrepair.com
- J
Posted on Jan 19, 2008
djproaudio
  • 515 Answers
SOURCE: How do I remove the Numark TTX platter
Nope, nothing to it. The platter is just held down by gravity. Take a mallet or a piece of 2x4 block, and give the spindle a little whack. Not too hard, just enough to break the hold.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
  • 42 Answers
SOURCE: Can't remove platter after removing lock washer
It should just lift off, but might be a little stiff.
Posted on Jan 25, 2009
  • 74 Answers
SOURCE: how to remove platter from AKAI AP-B110 turntable
On my Akai turntable, I have to remove the fiberboard bottom cover (nine screws, nothing tricky) then there's a central brass air bearing with a small set-screw in the side. Loosen the screw, and the central turntable axle lifts right out of the bearing.
This is a belt-drive Akai - your mileage may vary.
Posted on Oct 06, 2009
jeffbanko
  • 85 Answers
SOURCE: removing the platter to oil the motor shaft
PULLon it harder!!!! Its a *****! It will come up and off! Also do it evenly when you pull...there is a magnet under the platter. Dont break it! PULL evenly!
Posted on Apr 28, 2010
The belt came off my record player how do i put it back on
take out the plate. there is a small wheel that turns and a big wheel below the plate. You should put the belt around them both and then put the plate on it (be careful, it's heavy).
Nov 16, 2011 | Audio Players & Recorders
Belt fell off
There are two main types of phonograph turntable drives still being manufactured today, the belt-drive and direct-drive systems; the names are based upon the type of motor system found in each.
In a belt drive turntable the motor is located under and to the side of the platter and is connected to the platter by an elastomeric belt.
The design of the belt drive turntable allows the use of a less expensive motor than the direct-drive turntable. Also, the elastomeric belt absorbs motor vibrations which would otherwise be picked up by the stylus.
Jul 18, 2008 | Denon DP-300F Turntable
Platter wont spin on stanton t 120, all the lights turn on fine, platter seems to feel jammed, it wont spin easily when i push it by hand.
The belt that drives the platter may have shifter or the gears that turn the platter may be unaligned. Open it up yourself and check out the inside but be careful not to break anything or go into a local music/dj store. they may be able to help you for cheap or for free.
Mar 02, 2011 | Stanton T.120 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
Aiwa AP-2600 Direct Drive Turntable - platter not rotating
if the platter is removable by you and easily, might need just a little cleaning and lube at the center . the platter is the top rotating plate that you were pushing to get started.simply pulls out around a center key. check with local service shops how much they would charge for this kind of cleaning and lubing. $25.00 might be a good price to allow a decision, whether to buy a new.
Mar 05, 2010 | Aiwa PX-E860 Turntable
Motor turns feebly, not enough to make the platter
Sounds like the motor is bad if you say it turns feebly. See if you can turn the drive shaft with your fingers easily. If you find it hard, it's possible that something might have worn out. You could try oil in that case.
Feb 02, 2010 | Pioneer PL-990 Turntable
- OPTiC
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Jan 04, 2009 | Numark TTX1 Turntable
The platers arn't hard and heavy any more
Have you tried swapping out the platters? Sometimes this will fix the problem. Also, although VERY RARE, make sure you were sold the right platters with your turntables. I doubt they found a pair of copy cat platters, but ya never know!
You can remove them by just lifting them up and off. There is a magnet that holds them down, so if you encounter resistance, just tap the center shaft with a wood block, mallet, or similar. Don't hit it too hard, you just want to disrupt the magnetic force, and/or loosen the platter from the shaft (which sometimes gets stuck).
Other than that, I've never heard of this type of issue, and I repair these things for a living.
- DJ PRO LAB
www.DJPROLAB.com
May 08, 2008 | Technics SL-1210 Turntable
YES it sounds just like that what should or can I do to fix my hard drive???
Just a note, instead of making another post, you can just reply to it and I will get back to you just as fast. Well, sorry to say, but you can't do anything to fix it yourself. The problem (sorry if you don't understand) is apparently the fact that the read/write heads for some reason don't park themselves off the platter when you turn your computer off. This causes the read/write heads to stick to the platter, and the platter cannot spin. If you have a warranty, you could sent it back, but if it has expired, then there is nothing you can do except get a new hard drive, and don't get Maxtor next time, instead get a more reliable brand like Seagate.
Mar 24, 2008 | Maxtor Hard Drive
Turntable pitch control problem
sounds like the pitch needs replacing or tighting. Get them serviced. Ask your equipment supplier shop. Good way to check the decks are in sync is to place the pitch on each marked seting ie 0 / 2/ 4/etc making sure both decks are set to the same pitch adjustment speed. Look at the light from the on/off switch and check the 4x circles on the deck platter and make sure they are the same as each other. If you never used this before. set your eyes and pay attention, you will notice the pattern. I mix this way to get tunes roughly in time without listerning to the track - DJ EZ helped me with this years ago. peace DJ Nyce
May 30, 2007 | Technics SL-1200 Turntable
Technics SL-DZ1200 Turntable Logo
354 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
