Question about Western Digital (WDXB1600JBRNN) 160 GB Hard Drive
WD16008011-RNN making high pitch squeal and will not be recognized by computer
When I turn on the hard drive it makes a very high pitch squeal sound that increases and then decreases in intensity. The light is on, but the computer with Windows7 Premium Home OS does not see it, it is not listed as a drive. After a while a dialogue box pops up and says the hard drive need to be formatted, yes or no. I've unplugged the power and rebooted it several times, changed the USB cable and port, no luck so far.
  • 6966 Answers
SOURCE: wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Posted on Sep 17, 2007
SOURCE: External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
Posted on May 13, 2008
  • 7 Answers
SOURCE: hard drive not being recognized
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Posted on Sep 04, 2008
SOURCE: My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive
Well i got a simple 320 gb external hard drive, and since the first month i had problems, i solve the recovery issue by opening the hard drive, and find it out, the inside was broken, and it got unplugged. so plugged it back and got my info. if your data its more important than 200dlls or less break the thing open, because if you claim the warranty they are not responsible for your information.
Posted on Dec 13, 2008
  • 12 Answers
SOURCE: computer will not recognize wd1600c032
open up the case and pull the driver out. put the jumper to SL (slave) and plug it directly into *********** boards ribon cable after your windows drive (XP), if it does not recognize it try moving the jumper to the CL (cable select) see then, remember to turn off your computer before doing this each time. if either computer still does not see the drive the drive is probably bad. they dont last a long time if you leave it turned on and running all the time. they tend to get hot and burn out. if the drive it self is SATA you will need an adaptor, if its IDE (wide ribbon cable) it should plug in and be seen. hope this helps.
Posted on May 09, 2010
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
Aug 23, 2013 - Uploaded by
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
locating a sound is hard especially because you're driving. Most likely a high pitch sound especially when you let off is a vacuum leak, or leak around your airbox. Off the throttle the engine is at maximum vacuum. Look at hoses cracked or not properly pushed in
Jun 02, 2015 | 2008 kawasaki Vulcan 2000 Classic LT
Squealing noise from my unit
If it's new, get it replaced. If it's old, you will want to get a new one ASAP and copy your files off at the very least. Try to use it as sparringly as possible until then A hard drive making noise is usually a sign that it's on its last leg.
Mar 29, 2014 | Computers & Internet
Need schematic for harmon kardon ho-595 subwuffer
I had the same issue, definitely check your cable. if that's good try a different outlet. i had mine in the surge protector when it was making the high pitch sound. when i just went straight to the wall outlet by it self it worked great. hope this helps.
Mar 10, 2013 | Harman Kardon HK595 Computer Speakers
High pitch sound when driving but stops when brakes are applied?
I would check your brake pads to make sure they are good
Oct 06, 2012 | 1993 Nissan Maxima
I am trying to hook up a hard drive to my computer. The computer recognizes the fact that hardware has been added; however, it does not seems to recognize the hard drive itsself. It is a model number...
Test all leads that attach to your hard drive including electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
hope this will help
Aug 28, 2011 | Toshiba MK 3017GAP (HDD2159) 30 GB Hard...
WD WD1200B008-RNN not recognized by laptop/desktop
I had a similar problem with some other brand of external drive. I disconnected it without being stopped and then nothing would recognize it. It was new when this happened, I contacted the manufacturer and they sent me a files with software and instructions to recover it. It was not that easy since I'm no computer geek, it took quite a while but finally the drive worked again. Info was lost since I had to formated it, can't remember exactly is low level formatting but alive again.
Also try to go to my computer icon on the desktop and right click, go to "manage" there you'll see an option for disk management, there you might be lucky and make it work again.
Hope this helps, regards.
Feb 14, 2010 | Western Digital 120 GB USB 2.0 Hard Drive
After I plug in my graphics card it makes a high pitch squealing.
Unplug the board, don't put the side panel on and listen for the sound. Sometime a rolled up newspaper can be used as a stethescope and help determine the squeal location.
Mar 27, 2009 | Nvidia BFG GeForce 6800 Ultra Overclocked...
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Western Digital (WDXB1600JBRNN) 160 GB Hard Drive Logo
54 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
