Question about Dryers
How to open Kenmore HE4 (model 110.85872400) dryer to replace thermal fuse
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
TheMobilian
  • 8220 Answers
SOURCE: location of the thermal fuse on the kenmore gas dryer 80
Posted on Feb 04, 2009
vickygomar
  • 460 Answers
SOURCE: blown thermal fuse on Kenmore dryer
I need the serial# to assist you better.
Thank you for trust fixya.com
Posted on May 14, 2009
  • 2180 Answers
SOURCE: Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
Posted on Mar 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Jul 23, 2012 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE4 dryer and it is not heating up. I changed the coil and cleaned out the lint. Is there a reset button?
If it isn't heating up but running otherwise, you probably blew the thermal fuse. The thermal fuse is often blown by the high limit thermostat going bad, and thus may need to be replaced also.
Mar 10, 2010 | Kenmore Elite HE4 Electric Dryer
No heat
its complicated and not able to explain on this page but in any case the unit will have to be completely disassembled and if the igntr bad the thermal fuse ok but more than likely just the thermal fuse....... again its just more work than most people can perform but the first thing is the top has to come off first
Aug 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer 110.67032600
Have your thermal fuse and thermister checked if either is open which means blown the dryer will not function. go here and enter model number www.repairclinic.com
Mar 19, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore model 96284100 dryer
The thermal fuse should be connected to and near the heating element. Check the paper electrical diagram, taped on the inside of the dryer.
InMrFixIt
Aug 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
