Question about Petzl Camping, Backpacking & Hiking
Peltz tikka xp
Dont switch off
Can I get a silver stud that came out?
Check with Pelz Shoes to see if they have any if you are near there. Failing that, a shoe repair shop ought to have something like what you need or can get it.
Nov 16, 2015 | Clothing Accessories
Hp dv9205 wireless switch went out dont work what can I do
Depending on what operating system you have you can manually enable your wireless..
Google xp, vista, or windows 7 and add to it..enable wireless and you will get the instructions to enable the wireless without the switch.
Try it like this if you have xp
" Windows xp enable wireless "
Apr 08, 2010 | HP Pavilion dv9205us Notebook
Petzl tikka plus torch repair
I understood that fixya was free from reading the word free all over the place. I wasted my time filling in the form to find out it was not free, but only 7 days free trial but you needed credit card details before. I will not be the first to write this and am tired of being told things are free when they are not. Do not mislead people.
Jan 05, 2010 | Petzl Tikka Plus
Facewest quiz
I believe you are looking at power settings, range compairson
Nov 11, 2009 | Petzl Tikka Plus
Petzl Tikka switch is not working properly. Light not steady.
Would you describe the light as flickering and fading perhaps? Are you using rechargable or Lithium batteries?
Here's an excerpt from a Petzl alert put out a couple of years ago. It may shed some light on your problem..
LED light sources are susceptible to being damaged by the use of lithium batteries due to the different characteristics of lithium batteries in discharge. This has meant that some people have had problems with their headtorches failing when using such batteries... Petzl have reported this problem and other manufacturers are expected to follow suit. However this does not affect all head torches...
There are problems being reported over the LED lamps in certain headtorches when used with lithium batteries. Incandescent bulbs will also suffer a reduced burn-time when used with lithium batteries although this is less severe.
This is because the lithium batteries have a higher output during discharge.
The benefits of a lithium battery are the increased burn time, especially at low temperatures over the traditional alkaline batery.
LR6 or AA and LR03 or AAA are the two size of battery litkely to be used in a headlamp.
Petzl are one of the few manufacturers to advise on this at the moment. Other manufacturers products will also be affected.
The following Petzl headlamps should not be used with lithium batteries:
  • TIKKA / ZIPKA range: TIKKINA / TIKKA / ZIPKA / TACTIKKA / TIKKA PLUS / ZIPKA PLUS / TACTIKKA PLUS / TIKKA XP / TACTIKKA XP / TIKKA XP ATEX / TIKKA XP HAZLOC.
  • MYO range: MYOLITE 3 / MYO 3 noir / MYO XP.
  • DUO range: DUO LED 5.
  • SAXO AQUA.
  • MYOBELT 3
  • DUO LED 3.
  • Oct 12, 2009 | Petzl Tikka Plus
    LG KU990I PHONE
    chicken tikka
    Oct 05, 2009 | LG KU990 Viewty
    Petzl Tikka Plus Headlamp has a short and is eating batteries
    There's really not much that's serviceable in these things. Try cleaning all the terminals again but this time use VINEGAR instead of alcohol which does not neutralize the corrosion as vinegar does. Just dip a q-tip in the vinegar and swab it on the terminals, then with a dry one, swab up the excess. Then install all NEW batteries, do not mix old ones with new ones as the new ones cannot make the old ones work any better than they are used. If they still don't work, welome to the world of cheap products that are intended to be tossed when they quit functioning. Good luck. :)
    Apr 19, 2009 | Petzl Tikka Plus
    Buy riflescope!!!! Which one????
    Robert, I have the Simmons 6-21x44 MilDot # 511056 scope on my Savage model 10FCP Law Enforcement issue rifle. I think you should check it out. It has 90 MOA internal adjustment and you could get you something like a 15 MOA or 20 MOA tactical rail and push your adjustments out to 1000 meters!!!
    Oct 03, 2008 | Nikon Monarch UCC 6.5-20x44 AO Matte
    Camping, Backpacking & Hiking Logo
    47 people viewed this question
    Top Petzl Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Petzl Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
