Question about John Deere Garden
JD 80 EV oiler not working
Manual chain oiler not working
SOURCE: Chain oiler inop
this is a common problem and requires replacement of the pump. remove the bar and chain, the pump comes loose with a few screws. under it you'll see the filter which could be clogged, but not usually as contaminants are not likely to enter the tank. Small engine shops can order the new pump for you, hope this helps
Posted on Jan 02, 2009
  • 3 Answers
SOURCE: Makita DCS51018 Chain Saw Oiler
Before you tear apart and purchase a new oiling assembly. Remove the sprocket cover, bar, and chain. Above the bar studs there is a horizontal groove the oil should flow from. If it is packed with sawdust clean this out. After cleaning or it is clean start the saw with all of the items removed. You should see the oil flowing. If there is no oil the oil pump is bad or clogged. If it flows your bar is clogged. Clean the oiling hole on the bar and groove. Hope this helps.
Posted on Feb 27, 2009
  • 205 Answers
SOURCE: chain oiler
Saw dust has clogged the passage way in the bar. take the bar and chain off and clean the groove where the chain runs, also near where the bar mounts to the saw there are holes in the groove that intersect with cross holes in the center of the bar, push a paperclip through top and bottom.
If this works for you please leave a rating, thanks
Posted on Mar 25, 2009
  • 226 Answers
SOURCE: Can't get the chain oiler to work. Using standard bar oil.
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Posted on Apr 26, 2009
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
Thanks, guys. Right, I do fill it partially now, but it's annoying. Oh well, there is no simple way to restrict the line - I have disassembled the unit and one would only hope the designers would think about a simple device for adjusting oil flow, but there is none. Primitive, since oil will flow at very different rates in cold and warm weather...
Posted on Aug 16, 2009
Automatic oiler problem since date of purchase. Remedy?
No found recall for this. link below not your exact model, may help on repair of oiler
Chainsaw chain oiler repair
Jan 16, 2016 | Makita UC3530A 14" Electric Chain Saw
How does one replace the chain oiler in a 0009 Stihl chainsaw?
from stihl documentation it does not seem that you can replace it. I have appended the manual for you and an article dealing with chain oil delivery system for 0009
Stihl Chain Oiler Trouble
How to Unstop the Oiler on Stihl Chainsaw
http://www.stihlusa.com/stihl_ownersmanuals/009_manual.pdf
Jan 26, 2015 | Stihl Garden
Poulan 1950 woodshark
The first thing I would look for are cracks in the oiler lines. If the saw has a manual oiler try to see if that will get oil to the chain. Check to see if the cap on the oil tank has a plugged vent hole.
Aug 30, 2013 | Garden
What kind of oil do I put into my toro expand it chainsaw?
CHAIN OILER See Figure 18. ? Use Premium Bar and Chain Lubricant. It is designed for chains and chain oilers and is formulated to perform over a wide temperature range with no dilution required. ? Remove the cap and carefully pour bar and chain lubricant into the chain oiler tank. ? Replace the cap and tighten securely. ? Check and refill the chain oiler tank every hour when using an electric power head or every time the engine is fueled when using a gas power head. NOTE: Do not use dirty, used, or otherwise contaminated lubricants. Damage may occur to the oil pump, bar, or chain.
Sep 01, 2011 | Toro Garden
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Does my jonsered 451 ev have auto. chain oiler
yes it does. I have one and all I do is add chain oil to the reservoir and go. I've cut acres of trees and it always works great.
Sep 26, 2010 | Garden
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Our chain is not being oiled.
run some karosene through the oiler
Mar 23, 2009 | Garden
Garden Logo
29 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
