Question about Panasonic SC-BT100 Theater System
Bass too loud cant adjust - Panasonic SC-BT100 Theater System
Bass sounds are extremely loud and distorted. Do I have to send the set in for repair under the warranty?
If you can't adjust correctly bass, at a comfortable level and without any distortion, for sure you should return it on warranty!
May 04, 2015 | Mackie Onyx 32.4 Premium 32-Channel Analog...
I have a jvc kdhdr50......and I'm wondering how to adjust the bass and treble also how to turn the loudness on
This is discussed on page 26 of manual. Press and hold MENU and select USER for EQ. Under EQ you will have options to adjust SUB BASS, BASS, MID BASS, ULTRA HIGH, HIGH, MID HIGH, AND MID
Aug 10, 2014 | Car Audio & Video
Altec lansing 221 computer speakers sound solution
Unfortunately it looks like Altec Lansing goofed up on this set and didn't provide a bass control knob. You will need to use some sort of software equalizer on your computer to turn the bass down.
Mar 24, 2012 | Altec Lansing 221 Computer Speakers
I have a vsx-821-k reciever and cant adjust the bass
If the treble is good and is working then the failure to adjust or increase bass output even when it is done can be due to faulty OP-AMP in the BASS circuit. The BASS frequency must be enhance with an amplification and a pass filter with amplification boost and so a failure of this stage can be the reason for non action.You will need to have a signal test on the bass section to confirm the faulty IC.Check for poor solder joint and faulty capacitors/controls.
Dec 14, 2011 | Audio Players & Recorders
Bass strings are too loud in comparison to treble strings whe played through the amp
Adjust this using the EQ on the amp and to a lesser extent the tone controls on the guitar.
Often people boost the bass way up causing this problem.
Feb 12, 2011 | Epiphone Sheraton II Guitar Electric...
Hi, do you know if you can adjust the bass on a Sharp xl-hp505 micro component system (other than the preset settings)? I find the bass too loud. Thank you so much.
The manual mentions a couple of things that could account for excess bass, one being the Extra Bass button (X-Bass indicated on front); the other being the ROCK setting, which boosts bass.
http://www.retrevo.com/support/Sharp-XL-HP505-manual/id/285dj790/t/2/
Placement of the speakers relative to the room surfaces and the listening position can affect their perceived bass response. Experiment. Corners and close wall reinforce the bass, moving the speakers out from them would lessen it.
Jan 03, 2011 | Sharp XL-HP505 CD Shelf System
How to set gains, brand new amps dont kno much about car audio.. how do i tune my amp for loud bass
for loud bass is 120Hz the freq. and adjust the audio gain in scale 1 to 10 in 7.
Apr 24, 2010 | Hifonics XXV Sampson Car Amp
JL 13w7 & 1000/1 Settings
There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
Well good luck, and hope this helps!
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Cant adjust sub out and midrange like i used too.
Hello chev_454,
You can adjust the sound settings for bass, middle, treble, and sub out separately for each source, tuner, CD, AUX, etc. The adjustment procedure is on page 26 of the owners manual. If you do not have a manual, you can download a PDF copy here at Crutchfield. They show the Bahamas as a discontinued m,odel but the manual is still in their database.
Hope this helps.
Jun 02, 2009 | Blaupunkt Bahamas MP46 CD Player
Panasonic SC-BT100 Theater System Logo
21 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
