Question about Airis T620
Forgotten 4 digit password Airis T620 Pocket PC
I need the PUK or reset code to reset forgotten password on my airis t620.
  • 2069 Answers
SOURCE: airis t620 will not open
did you follow the exact hard reset procedure. check here.. do it again and please post back for a followup.
thanks
Posted on Sep 21, 2011
I forgot the password manually fiwed to turn it on.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Nov 12, 2012 | HP Ipaq Hstnh-h09c-wl Pda Windows Pocket...
Tip
Lock Code, Pin Code & PUK code
Lock code: 1. 5 digits, Used to prevent unauthorized access to certain functions on the phone 2. Where: Tools > Settings > Security > Phone & SIM 3. Default: The default lock code for Nokia Series 60 devices is 12345. 4. Forgotten - If you've changed this code and forgotten it - you will need to visit a Nokia authorized service center, who will be able to reset the lock code for you. PIN code 1. 4 digits, an optional 4 digit code to protect your SIM 2. where: Tools > Settings > Security > Phone & SIM 3. Forgotten -If you keep trying, you'll eventually get locked out and need to contact your network operator for a PUK code PUK code 1. 8 digits, You'll be asked for this 8 digit code if you've entered the wrong SIM code more than the allowed number of times. You'll need to contact your network operator to get this lock lifted.
on Jul 30, 2007 | Nokia E61 Smartphone
I want to know why you have taken $12 US from my account when the problem has not been fixed? The last time I was in contact with you I told you that when I connected the PDA to the computer to transfer...
go to settings
then to connection setting and there you will find pc connection or something related to computer
then chose what you want mass storage or the other options
but for the other options, you'll have to install their software on your pc
better try the mass storage
Nov 02, 2011 | Airis T620
Hi, I forgotten my password for my N560 Pocket PC...Is there any way to reset the device or access it to change the password? Thanks
OK so you have to perform hard reset.
You do this by pressing and holding the power and calender button, then pressing and releasing the reset button. You continue to hold the power and calender buttons for a few seconds. When you release the power and calender buttons the unit should beep and then reset.
Apr 09, 2011 | Fujitsu Siemens LOOX N560 Pocket PC
I want PUK number of My sim
You actually have to contact your service provider and they will be able to get you your puk number or replace your sim card.
www.usedcellphoneshop.com
Jun 07, 2010 | Airis T620
I forgotten my HP iPAQ 112 Classic Pocket PC password.Is there any solution besides trying to remember the password?
you can try a hard reset(hold the 2 corner buttons down then using stylus insert in the small hole on the back for soft reset) this will restore factory settings. if you have sync folder on your computer you should be able to retreive contacts, pics, etc. hope this helps.
Aug 27, 2009 | HP iPAQ 112 Classic Pocket PC
How to reset imate jamin password?
You can try with hard reset, i am not sure if it will work : keep pressed volume - , on/off button and reset button( from the bottom side of the device) for a few seconds
Jul 18, 2009 | i-mate JAM Pocket PC
Forgotten password, cant rememeber, wan to reset to factory settings
nothin cant be done is this situation , take it to the service centre
May 24, 2009 | HP iPAQ HX4700 Pocket PC
Blackberry curve 8300 password forgotten how to reset need to reset
Yes, if you enter passwords ten times, it will run a master reset on it, clearing all data. On the 8th bad password, you will have to enter the word 'blackberry' too, but that is to keep small children from running a master reset by playing with it.
As to the users with jvm errors, you will need to install Blackberry Desktop Manager on your PC, and reinstall the BB software. Both the BBDM and the software can be found at www.att.com/bbdownloads.
Oct 28, 2008 | AT&T Blackberry Curve 8300 Smartphone
Airis T620 Logo
138 people viewed this question
Top Airis PDAs Experts
Are you an Airis PDA Expert? Answer questions, earn points and help others
