Question about Singer 7442 Mechanical Sewing Machine
How to loosen presser foot on a 4832c singer - Singer 7442 Mechanical Sewing Machine
  • 323 Answers
SOURCE: what free motion foot can you attach to this singer 3116 model?
This low shank foot will work on that machine. Singer 3116
sewman7
Posted on Dec 05, 2008
  • 27 Answers
SOURCE: I have a Singer sewing
more than likeley the set screw is loose on the presser bar shaft ,remove the endcover and take a look should be simple
Posted on Jan 10, 2009
  • 22 Answers
SOURCE: Top stitch looks good, bottom stitch is loopy
this is a common problem, don't worry it's easy to fix.  take the spool of thread off, remove the bobbin.  look for any stray thread pieces in or around the bobbin case, rethread the top of the machine and when you do, follow the threading guide precisely and ---here's the trick---make certain that the thread goes between the tension discs.
Posted on Jan 17, 2009
  • 51 Answers
SOURCE: singer 6038
The presser bar is not moving, there is a set screw that controls the presser foot height on the bar, it may be to tight. Take the side cover off, and look for the presser bar, the set screw unit should be facing you. Unscrew it and see if the presser bar handel will now move.
The presser bar height should be set at 7 mm. To make an adjustment loosen the set screw. From the top of the machine, press down firmly on the presser bar and then secure the set screw.
Posted on May 13, 2009
mohammed387
  • 1952 Answers
SOURCE: My singer simple presser foot and pressure bar
Take the back of the machine off and inspect to see what is stuck. If there is something stuck, remove it.
Posted on Jul 26, 2009
Presser foot doesn't go down. Presser foot lever goes up and down but the presser foot does not. Singer sewing macine.
There may be a disconnection between the lever and the presser foot bar. Perhaps a screw has fallen out, broken, or is loose? May need to take it for service.
Sep 25, 2017 | Singer Sewing Machines
How do I attach the foot to a singer 258 fashion mate?
The large screw on the left side of the presser foot bar tightens and loosens to install or remove the presser foot.
How to Thread Singer Sewing Machine Fashion Mate 257 Wind Bobbin
Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwickoTdgoXUAhXLh1QKHUPYAA8QFghBMAQ&url=http%3A%2F%2Fparts.singerco.com%2FIPinstManuals%2F1191D200A_258A_300A_558A.pdf&usg=AFQjCNEGM29HS1mX9tm3XU88FIK_zM0VCw&cad=rja
May 23, 2017 | Singer Sewing Machines
How do I reset the presser foot pressure back to the factory default on the SINGER 1507wc?
Once the presser foot pressure adjustment has been made it is a matter of matching the pressure to your fabric. Using a coin turn to button clockwise to tighten ( as for heavier fabrics) and anti clockwise to loosen (as for lighter fabrics). It will be up to you to find just the right settings depending on type of fabric and thickness.
Jan 01, 2015 | Singer 1507WC
My Singer XL 6000 upper thread is too tight and keeps breaking, when the presser foot is up the upper thread is loose, but when the presser foot is lowered the threah gets too tight, what I notice is that...
You need to loosen the tension on the machine. There is a dial that has numbers on it. The higher the dial is set, the tighter the tension is. Turn the dial to the left one number. Then try it. Do it over and over. Do not turn the dial all the way down or you will mess up your machine. Do it slowly, one number at a time and try the machine between dials.
Dec 22, 2014 | Singer Sewing Machines
Vintage Tough and Sew Model # 628 PRESSER FOOT QUESTION!
You should be able to figure out which shank your machine has here:
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
If you have the manual, it should show you how to change the presser feet.
SINGER Instruction Manual pdf model 628
If your machine and presser foot look like the one in the video, the screw on the left side of the presser foot should be what holds the presser foot in place.
Singer Touch and Sew Threading and Bobbin Winding
There may be other videos here that would be helpful.
Jun 06, 2017 | Singer Sewing Machines
How do i install the darning foot?
Make sure that you have a darning foot that is compatible with your machine. I believe that the 7422 is a low shank foot; the appropriate daning foot is http://www.sewingpartsonline.com/darning-foot-singer-006016008.aspx . Lift the presser foot and remove the foot currently on the machine, including the ankle. (Loosen the screw on the left side of the ankle.)
Place the darning plate over the regular plate and feed dogs. The pins should lock into the spots on the machine.
Place the U-shaped opening of the darning foot over the screw that you loosened previously. Then tighten the screw to hold the foot on the machine.
Lower the presser foot onto your fabric. Set your stitch length. Lower the lever on the right side of the darning foot and hold onto your top thread (assuming the needle and bobbin thread are already threaded.) Now sew.
I hope this helps.
Aug 10, 2011 | Singer 7422
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Dec 31, 2009 | Singer Sewing Machines
Model 4832c
guide the the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)If it doesn't work like this, then there is probably thread stuck inside the tension assembly. Set the tension to zero and blow hard between the discs to dislodge the thread. If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
Check to be sure you have the correct bobbin and that it is inserted the correct way.
OR remove the needle plate to remove the bobbin case. Look for any burrs or rough spots. Use a fine emery stick and steel wool to remove and buff them Reassemble and try again.
Sewman7
Jun 17, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 6038
Apr 07, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
42 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
