Question about Fisher Scientific Isotemp 500 Series Economy Lab Oven, 120v 50/60hz,
Fisher Scientific* Isotemp* 500 Series Economy Lab Ovens
Can a replacement stir rheostat be purchased for a fisher scientific hot/ stir plate model 11-500-4sh.
The value of the rheostat will part of the numbers on the metal case. You should be able to get ons from Radio shack or online.
Aug 11, 2016 | Kitchen Appliances - Others
Need the resistance VS temperature table for the 15-077-8 probe
http://www.omega.com/techref/pdf/z252-254.pdf
google it RTD to temp
this will not tell you if probe is reading correctly, display is just converter and calculator, probe is the one that measures and supplies result. If you have 3458A you have access to lab equipment and should ask someone how to calibrate this
Aug 08, 2016 | Fisher Scientific 15-077-8 - Scientific...
EO2 error -what does it mean, can it be fixed? How do you fix it?
It depends on the cause which can be a short circuit or faulty thermocouple, element failure or the opto/triac driver faulty.
You can check the error codes in the attached link http://www.torontomicrofluidics.ca/cms/manuals/hotplate.pdf
Apr 23, 2015 | Fisher Scientific Isotemp Basic Ceramic...
Screen is blinking
when I try to send something from pinterest to another person the screen flickers, won't send anything and takes me to the top of the page what is wrong
Sep 04, 2013 | Fisher Scientific Isotemp 2150
Need manual for "Fisher Price DC Super Friends TRIO Joker Laugh Lab W2061"
here you go..
http://www.fisher-price.com/inst_sheets/W2061pr-0920.pdf
don't forget to rate the solution if that's it so it can be of help to other people as well
Dec 30, 2012 | Toys
TEAC AR-40S MANUAL
go to manuals.com & purchase it. got to make the economy work.
Jun 07, 2012 | Fisher 500-c Service Manual & Owners...
How do I start my 13-986-144A isotemp plus, I have no manual and I don't know how to access the control menu... help...
The first thing that you should do is plug the AC cord of the freezer and open the upper portion on top of the two doors and insert the key on the slot and turn it on. Open the freezer door and locate the temperature adjustment panel inside and adjust it to your desired temperature.
Nov 17, 2010 | Fisher Scientific Freezer Isotemp* Plus...
How can I turn the defrost off ? because we don't like the defrost function when we store some liquid reagent.
Freezers should defrost as perscribe to prevent build up of ice.However it would not be long enough to cause listed problem.
If things are defrosting as stated, there is a problem other then the defrost
May 20, 2010 | Fisher Scientific Freezer Isotemp* Plus...
Problems with an older Fisher Isotemp plus 98 model, the defrost circuit is not working correctly. The temp is normally around -20 degrees celsius and the temp is now at -08. I have manually defrosted the...
Noah had one of these in the ark...he did a full defrost(left it for 24 hours with the doors open then cleaned the vents/drains)and his was fine after that,hope this works for you.....also check door seals for tight fit all round.
Apr 06, 2010 | Fisher Scientific Freezer Isotemp* Plus...
Manual defrost
On my upright freezer I use pans or trays I have and set them in the bottom where it catches nearly all the water. I don't have to empty them till it's all melted because it till hold all of it.
Sep 06, 2009 | Fisher Scientific Freezer Isotemp* Plus...
Fisher Scientific Isotemp 500 Series Economy Lab Oven, 120v 50/60hz, Logo
74 people viewed this question
Top Fisher Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Fisher Health and Beauty Expert? Answer questions, earn points and help others
