Question about GE 32GT660 32" TV
Unhooked the TV,took it to another room, hooked it up, just fuzz
We have dish network, the TV was working fine, we unhooked the TV and we moved it into another room, we hooked it up to the cable for Dish and plugged it in and now there isn't any picture just fuzz. I can't find the book.
  • 55 Answers
Make sure the cable you now have hooked up to TV is actually hooked up to the dish. If you're sure it is then take the TV back to original location and hook it back up. If it works in that location you have a bad cable. If it still doesn't work it's the TV. The only other thing I can suggest is that some TV's must autotune before a picture can be shown. If you're sure you have a ggod signal go to the TV menu and do an auto tune or auto search. The TV will then go thru all the different possibilities looking for signals. Once it has completed the search it will then give you a picture. You can then go and add/delete channels and set it up however you want.
Posted on Feb 18, 2009
Had my playstation 3 hooked up to my old television in the living room, i recently got a new tv for my room so i unhooked it and took it upstairs and plugged it in and it isnt working. no audio or video....
If it works with your Wii and not with you PS3, chances are your audio / video cables were damaged in the move. Try hooking up your PS3 to another TV with the same cables. If you have audio and video on a different TV with the same cables, it may be a problem with your HD settings. If the cables for the Wii aren't HD component cables and the PS3 cables are (or vice versa) this could be causing the problem, as the HD component cables have a different plug in than the normal video / audio settings. If this is the case, search around your TV to find the alternate connections and try those (these will probably require a different channel). If none of this works, I suggest you contact Sony about the problem and perhaps even send in your Playstation for repair. If you need anything else, let me know!
May 19, 2011 | Video Game Consoles & Games
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Console will not work
you should never unhook or hookup anything hot. shut your stuff down and then plug unplug whatever it is you are doing
good luck cullen
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Mp3 was working, then it stopped
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 22, 2008 | Audio Players & Recorders
Ghosts on my tv
if you can, try hooking up the tv to a different cable line in the house or bring a different tv into the room where the bad picture is [ you may have a bad connection or wire ] if this doesn't help, try rabbit ear antennas just to get a picture. if you still have ghosts on your tv, the problem is with your tv.if the picture is fine, there maybe a problem with your cable service.
hope this helps
wg
Feb 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Nothing but snow
Your explanation about a different TV receiver working OK on the same aerial connections leads me to believe you have lost the tuning in the faulty receiver...
Just "snow" with no sound is a classic response for lost tuning....
It shouldnt have lost the tuning as there is a small battery(capacitor) that holds the previous receiver channel settings when you turn the TV off. But as you have had the Receiver in the back of a truck and disconnected from the power supply for some time then this is probably the culprit....
This battery (Capacitor) may be getting old and has lost its capability of sending a minute amount of current to the tuner IC (Chip) ...to hold your previous channel settings...So if you can retune the receiver to the output from the Dish Network Receiver you should be fine again, but if the battery is shot you need a new one....or just leave the Receiver in the standby mode for a couple of days to re-charge the battery (capacitor) up.
You will need a service technician to replace this small battery (capacitor) its a special type made just for your receiver....
Hope this helps
YUBEUT..
Oct 07, 2007 | Philips Magnavox TS3260C 32" TV
Televison & Video Logo
169 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
