Question about Kohler Forte entertainment remote valve sink faucet with Sidespray ...
Kohler R10412-CP-Ab leaking around base - Kohler Forte entertainment remote valve sink faucet with Sidespray ...
3 Suggested Answers
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 68 Answers
SOURCE: kitchen faucet
look under your sink there will be a big nut screw it up toward the counter top this will fix your problem also may want to look into getting a prv for your house this will lower your water pressur in your house
Posted on Mar 15, 2009
I just installed a Kohler Forte R10412-N-CP. Hot water flow is good. However, very low cold flow. What's wrong
First turn off the shut-off valves and remove the Forte faucet inlet hose from the cold water line. Then put a temporary inlet hose on that shut-off valve. Test how much water flows into a bucket when you open the valve. Assuming that you had good flow from the cold water shut-off valve through the supply hose, a trickle flow on one side suggests the cartridge plunger (mixing valve) or the inlet hose is blocked or damaged. Since this is a new unit, I'd recommend you replace the faucet. The best option may be to take it to the place where it was purchased (depending on the return policy).
I hope this helps and wish that I had better news for you.
Feb 06, 2015 | Kohler Plumbing
Where can I purchase a new Kohler 85330-cp-17 Teal replacement molded wood elongated toilet seat for our existing toilet?
You cannot. As you state, it is discontinued, confirmed on Kohler site.
If color is really important, consider painting it or a new replacement using an appliance epoxy spray paint such as Rust-Oleum after careful preparation of the surfaces.
Jun 13, 2014 | 85330-BR-17 Part - Teal Assembly Seat-...
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
Leaking hot water seal
leaking around handle?Turn water off under sink.remove handle,cover plate,unscrew valve stem assembly,and turn the two pieces apart to expose o ring,and replace
Jan 27, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
Why would spout leak at the swivel?
The swivel base needs to be tightened. There is a gasket underneath.
Jan 09, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
Kitchen faucet
Mar 13, 2009 | Kohler Forte entertainment remote valve...
Nov 12, 2008 | Kohler Forte entertainment remote valve...
Kohler Forte entertainment remote valve sink faucet with Sidespray ... Logo
314 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
