Question about Toshiba TDP XP2 DLP Projector
Toshiba tdp xp2 white dots
My brother's projector is showing white dots on the screen when it is on. He asked me to look into it. Is the only solution to replace the dmd chip?
  • 7 Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
Marrie
  • 563 Answers
SOURCE: Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
Posted on May 21, 2008
SOURCE: Toshiba TDP-T90 projector, lamp
I have the same problem. The lamp cover has a tab that sticks up about 1/2 inch. When you close the lamp cover the tab presses on a wire that allows power to the lamp. You can hear a 'click' as you close the cover slowly. My tab kept bending over preventing it from depressing the wire. I've straightened it several times to where now it broke off to where it wouldn't work at all.
I fixed the problem by clipping off the tab, inserting it in the bulb case to press the wire and taped the tab in place.
Posted on Dec 02, 2008
  • 4 Answers
SOURCE: The color went out on my Toshiba TDP-T45
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Posted on Jun 24, 2009
  • 4 Answers
SOURCE: Toshiba tdp t45 dlp projector broken segmented colour wheel
23125963 is the Toshiba part number. Expect to pay about $65 on line. Google is your friend!
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
Hundreds Of White Dots On My Display... Looks Like Stars!
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
Mar 21, 2012 | Toshiba TDP-SP1 DLP Projector
Toshiba xp2 projector overheating
Better late than never for any other XP2 owners out there. I've gone through 1 lamp so far with very good results. The key to overheating is cleaning the fan out, i.e. it sucks in a lot of dust particles over time which accumulate on the fan blade and in the vents blocking good airflow. Take a good strong vacuum hose to every vent, then again right when you turn it on. This will get the fan up to speed quickly and assist with removing more dust internally. Eventually, you'll need to open the projector up and clean internally (carefully), but doing the above maintenance will prolong its life and extend the lamp too!
Feb 22, 2012 | Toshiba TDP XP2 DLP Projector
It suddenly stoped playing clearly. i can see some extremelly pale picture.my lamp is around 2000 hrs the projector is a 2004 model toshiba TDP-D2.any ideas?thanks panos
You need a new lamp. You can purchase one at:
http://www.shopvsc.com/Toshiba-Replacement-Projector-Lamps-s/143603.htm?searching=Y&sort=7&cat=143603&show=50&page=1&f-TDP%20D2=143381
Oct 25, 2010 | Toshiba TDP-D2 Projector Lamp
My projector is showing multiple white dots, looks like lots of small stars all over the screen when projected to screens. is this mean I need to replace the lamp? TDP-XP1 model.
Oct 19, 2010 | Toshiba TDP-SP1 DLP Projector
How to reset lamp counter of TDP S8 Toshib Projector
It would be in the manual
aboutprojectors (dot) com has them if you dont
PLease rate my help if this helps
Thanks
Aug 25, 2010 | Toshiba TDP-S8 Multimedia Projector
My TDP-S35 suddenly went to showing only in black and white. Any ideas? It was working perfectly and in the middle of a class it lost all color.
if this is a DLP projector, take the cover off and check the colorwheel. It sound to me like you have lost the segments off the colorwheel.
May 17, 2010 | Toshiba TDP-S35 DLP Projector
It shows no signal
Toshiba TDP-S8 projector cannot communicate from my laptop, it shows no signal. how can i fix it? thank you so much...
Feb 19, 2009 | Toshiba TDP-S8 Multimedia Projector
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP XP2 DLP Projector Logo
70 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
