Question about Air Tools & Compressors
Wrong direction of rotation
I need to change from CW to CCW on an A O Smith 5 hp 3 phase type MOGB on a 184T fram motor. there are 12 wires that tie to 3 and 3 are tied together. what3 wire need to tie to what wire and which3 to L1,to L2,to L3 ? 4 grops of 3 each wire has a letter and number on it.
  • 70 Answers
Swap any two leads L1 to L3 this will change rotation hope this helps a common color code is brown orange yellow in that order known as BOY at power feed you can change the wires at the disconnect load or motor side
Posted on Jan 24, 2009
How to use a phase tester
Voltage should be same across all Hot legs on single-phase and 3-phase circuits:
Test each Hot to ground wire.
http://waterheatertimer.org/How-to-wire-phase-monitor.html
Nov 16, 2017 | Electrical Supplies
I have a 1 1/2 hp 230/110 marathon single phase motor controlled by forward reversing starters with 24 volt controlled. How do I wire this motor up for for/rev ???
You need to determine at which voltage you will run this motor. A motor starter mechanically and electrically interlocked for F & R. with 24v transformer, a SS and FR station. This is expensive but sweet, needs room for this equipment.
The easy budget is by using a drum switch.
The motor nameplate or splice box cover will hand the info on how to connect the motor for either voltage and for CW and CCW rotation.
The magnetic motor starter also will include a wiring diagram.
Nov 04, 2017 | HP Air Tools & Compressors
This is a single phase 1/2 horse motor want to change rotation
yes all you have to do is rewire the wire the motor there should be a diagram om the inside of the the motor panel... dont forget to unplug it first!
Apr 03, 2013 | Air Tools & Compressors
Replacement fan motor for weather king 14AJA36AO1 condensing unit
You dont need all that data , most motors are belly band type 5" motors, the direction of rotation, hp, speeds, etc are whats material to you.you dont have to get that exact motor unless you wish , Any similarly sized, or larger hp motor will work,(never less hp though) GE makes universal replacement "tripsavers" that have a shaft you may cut if required, and reversible rotation, either CW lead end or CCW lead end, (leads being wires, not the shaft end)Unless you have a OEM specific design as in tabs mounted to the motor, you dont need the exact make, just parameters of equal or greater power and similar or reversible settings specifically. Just take that motor into a electric motor shop, sometimes will be called "X" armature, etc or a appliance parts house, Standard appliance, Jonstone supply, Graingers, Burke engineering, etc.I like GE replacement motors with poller bearings, rather than the Emerson needle bearings, or similar lesser quality motors.
Jan 24, 2012 | Weather King 10AJA3601AH Air Conditioner
AO Smith SQ1102 pump motor: how do I wire this thing? How do I know if I set it to 115 or 230? I justed popped my 20 amp fuse.
On your motor name plate there is a diagram with motor terminal numbers that shows you the feeder wires connections for 115 & 230VAC. You don't need to change any internal motor wiring connections because those are only CW or CCW motor rotation. As you told it tripped your circuit breaker, b4 u will attemp to make any connection you need to test your motor's winding insulation insulation first by using megger tester or ordinary analog tester clipping one lead to the casing and one lead to the motor terminals one by one.
Mar 06, 2011 | A.O. Smith SQ1102 Pool Pump Motor
Wiring diagram for 230v
Single phase motor for 230V, connect T4 and T5, to one line. T2, T3, T8 common connected. T1 to other line. Check Rotation, This should be for CCW rotation facing output shaft. Swap T5 and T8 for CW rotation.
Jan 17, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Runs ccw needs to run cw hp 5 460 v hz60 wired motor for high volts last 3 wires are orange that went to no.2fc yellow went to no.3 black wire went to no.1
Look you are putting to much thought in to this. To reverse the direction of a 460 volt motor simply swap two of your power feed leads. You know the L1, L2, and L3 simply change L1 with L2 and your direction will change, calm down and do not over think this.
Dec 28, 2010 | Universal Remote Control Heating & Cooling
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
What does line and tape mean dayton motor
L 1 is power in .L 2 is also power in.line means this is were the power needs to be hooked to . cw / stands for clock wise rotation . ccw stands for counter clock wise rotation.
Sep 28, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
194 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
