U-Line 75R Refrigerator
Problem for U-Line 75R Refrigerator
Uline 75R refridgerator stopped working
By don_willis on Jan 24, 2009
The light worked so it was getting power. I used a electrical tester (pencil like device I bought at lowes) to figure out that power was making it to the thermostat (black wire) but not after the switch (blue wire).
To change the thermostat.
1) take cover off the front bottom and back panel of fridge.
2) unscrew the old thermostat. leave black and blue wires on it so you will know where to put them on the new one.
3) take out glass shelves on inside. Unscrew back panel. There are 2 phillips screws that hold the end of the thermometer to back panel.
reach hand under it and feed the thermometer back through hole and out back of fridge.You will notice a puddy like substance that fills in the hole in the back where the thermometer gets fed through. Make sure you keep it to fill in the hole in the back.
4) feed new thermometer end through hole in the back and install to back panel. Put the puddy back in the hole to insulate around it.
5) feed the electrical end of thermostat through bottom of fridge
6) take the wires off the old one and attach to the new one.
7) attach the thermostat to its mounting location
8) reinstall all the screws in the front and back and you are in business.
Had a hard time finding someone to service it. They wanted $200 to come out to the house + parts and labor.
The new thermostat cost $33 at All Brand appliance. I am from Mass and picked it up in Brockton. I emaile dU-line and they sent me the new part number. The allBrandappliance site had the old part number (2766-s)
I am not an electrician and this was a few hours work.
Solution #1
posted on Aug 14, 2009
Not Rated)
admiralstopf
Rank: Guru
Rating: 91%, 86 votes
Sounds like you did everything right
Was this helpful?
Yes
No
Popular Solutions for U-Line 75R Refrigerator
Questions and Unsolved Problems for U-Line 75R Refrigerator
Do you recommend U-Line 75R Refrigerator?
Answer
Answer
I have a U-Line 75 Bev and need to replace the temperature control but cannot find the correct part... (More)
Answer
I had a flash of light and electrical smell from my bar area, I moved the fridge to ck outlet,... (More)
Answer
the norcold in my motor home works fine on propane, but not on ac or dc! could it be the heating... (More)
Answer
There is a small ledge container on the back wall of the fridge which extends across almost the full... (More)
Answer
gss22 ifre ge refrigerator,Have new part but it is a replacement to original wiring is not the same.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
