Question about NEC NP60 Projector
Nec np60 cooling pump - NEC NP60 Projector
Vupoint dv-dv1-vp camcorder needs a new battery
Buy a "np-60" battery on ebay or other store. Some will come with a charger.
You can charge the battery via the usb cable from any working usb port.
Mar 19, 2008 | VuPoint DV-DV1-VP Camcorder
Np50 I replaced the bulb but still no light and red light blinks 8 times. Suggest needs cooling pump. Where can ibuy pump
Just clean the unit first. It might be clogged and not able to breathe. The lamp gets hot and needs the air flow.
Oct 16, 2014 | NEC NP50 Projector
I want to by a battery and charger to a camera figilife ddv-5300
Google search for NP60 batteryBattery is an NP-60
The company's website does not provide information regarding the power adapter. Can you provide photographs of the power socket and the markings on the camera body indicating the voltage and polarity of the connection? Otherwise, most links to "chargers" are for battery chargers for the NP60.
Aug 02, 2013 | Cameras
Help statius orange light 6 times lamp error try again in a minute. Still not working???!!! Help
Is the lamp and cooling pump covers on properly. It is saying that there is a lamp failure. Do you hear the high voltage trying to start the lamp when it turns on
Jun 30, 2011 | NEC NP60 Projector
What is the purpose of the coolong pump? What sort malfunction could occur due to that?
This system uses a cooling pump, to pump high pressure / high velocity air around the lamp dramatically improving cooling efficiency.
With this new cooling system, the body can be further reduced in size compared with ordinary projectors that use a single cooling fan.
If the cooling pump fails then the lamp will overheat and shut down
Apr 11, 2011 | NEC NP50 Projector
Suddenly stops showing the picture
The cause is a sudden overheat but when restarted its fine then it goes again this intermittant issue is with the lamp beleave that or not i found replacing the lamp solved the issue perm.
Thanks and please leave postive feedback..
Nov 17, 2009 | NEC NP60 Projector
Camcorder
Your in luck. Cheap but it does the job.
http://www.power101.com/search.htm?search=np60
The battery- a whopping .21cents each.....yes...not a typo...and the charger...hold on to your seat.... just 2.01. I have done business with them before....you pay a hefty shipping charge of about 5.00 the first item and about 3 something after that. till not a bad deal......
Take Care
Kevin
Jul 31, 2008 | Nisis Pocket DV4 Digital Camera
Vupoint camcorder battery
This camera is designed to use a rechargeable Lithium Ion battery.
(1050mAH) NP60 Lithium Ion Battery
Available from many websites, including:
http://www.nextag.com/np60-lithium-ion-battery-3.7v-1050mah/search-html
Also available from many stores including Wal-Mart, Best Buy, Circuit City, and Radio Shack
Vupoint camcorder has a dead battery
Recording/other info avail in user manual:
http://www.vupointsolutions.com/support-dv.asp
NEC NP60 Projector Logo
296 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
