Question about Brother IntelliFax-2820 Laser Fax
Where can i find little lavender piece in the back of the paper tray that holds paper in place ?
Could replace whole paper tray if I have to but just need little plactic piece nummber on back of piece is Lm4152
2 Suggested Answers
  • 320 Answers
SOURCE: Broken piece from jammed paper tray
what did you break off?????? let me know so i can help you
Posted on Jan 20, 2009
Clean a KX-P7100 printer
The paper jam in theKX-P7100 is usually due to the paper tray.
If you pull the paper tray out you'll notice a black piece of plastic (located at the most front) with a cork like material in the middle. Try pushing down on this piece of plastic a few times. If it does not pop up immediately the grease that Panasonic used has become "sticky". The piece of plastic is removed by turning the tray upside down and pushing on the small plastic tabs that hold the black piece of plastic in. Be careful to not loose the spring that is located under the black piece of plastic or break the plastic tabs that hold it in place. Once you get the black piece of plastic out, clean it with que tips and clean the area it slides up and down in. Make sure to remove all the "sticky" grease. Once you get it clean, don't forget to stretch the spring to one more inch. the spring quality is awful at tensile strength. Then place the spring back in its place and push the black piece of plastic back in its place. You can add some light oil to the black plastic to make it slide better. After it is reassembled try pushing down on the black piece of plastic a few times. It should spring up almost immediately. This should take care of the jams that you are experiencing.
In addition, you may have to stretch the 2 big springs under the metal plate in the paper tray to one more inch. To access them, you'll have to unscrew the 3 philips screws under the tray (take a picture before :-)), take away the 2 blue pieces and take out the metal plate.
Now I'm able to print from the media tray without any problem :-).
Hope this helps!
Dec 09, 2012 | Panasonic KX-P7100 Laser Printer
HOW DO I CLEAR THE PAPER JAM 1? I opened all the doors and checked to see if any paper is stuck somewhere. There is nothing to keep it from starting again.
Did you check the fusing section from back door? When you open the rear door you can access the fusing unit (hotest place!!!). Sometimes the paper stacks below the stripping pawls of hot roller and you can't see it easy. Look harder! Pull out the whole paper tray and check below (printer bottom) for paper sheet. Lift upper cover and remove cartridge. You will see little green lever. Lift it up! Look for piece of paper around the little black pawl (paper sensor after registration roller). Restart printer!
Good luck
pifonski
Mar 03, 2011 | Samsung ML-2150 Laser Printer
Won't print...sends a message that the papaer is out
Had exactly the same problem. The solution was a piece of scotch tape. Open the small paper tray, and position the paper guide (the rear one, not the side one) so that you can put your paper stack down with a little bit of looseness, then tape it down so it can't slide back and forth anymore. Now put the paper back in. This worked like a charm for me. Turns out the rear guide was a little too loose so that everytime the paper tray got sucked in, it would push the whole paper stack backward and then the rollers couldn't find the top sheet to feed into the printer.
Sep 15, 2009 | HP Photosmart D7260 Printer
Upper Paper Tray light flashing as if not all the way when it is.
Remove the paper tray.
On the right side you will see Three (3) holes
the plastic piece you found when in the bottom hole.
Since it is broken it will no longer snap into place.
Make your self fom either plastic or cardboard, a piece that will cover the bottom hole but not so big that it will block the hole above it.
Then using a good stiff tape (eloectical or duck) paste the piece over the hole, making sure you don't block the hole above it, or any other part of the machine.
I have taken a plastic knife cut to size and superglued it in.
If all else fails you can order that plastic piece that broke from Xerox. It's called a paper size sensor. about $5.00 for the part and about $10.00 for shipping.
Good luck
Luan
Jun 21, 2009 | Tektronix Phaser 860 Thermal Printer
My paper has been jamming when fed from the back. I found a foam piece that has come from somewhere in my machine. the piece is about eight inches long and seems that it might have had an effect on the...
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 08, 2009 | Canon Pixma MP800 All-In-One InkJet...
Paper tray is broken on laser printer Brother HL-5140
I believe you have to call you manufacturer and ask if you can purchase the tray separately. They might also give you a company that manufacture's parts of their printer.
Unfortunately I don't have any number about brother but you can visit their website and you might find their number.Their website is www.brother.com
Feb 27, 2009 | Brother Office Equipment & Supplies
Paper tray stuck
On the Brother DPC130C
Take off the back cover, sort of triangular piece of plastic.
Take power cable out, turn the device on its side and look at the back in the centre there is a white piece of plastic lift that up with a ruler or such device lift the white plastic thingo and slide the tray out.
Don't forget to put all pieces back in place before using printer.
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Brother IntelliFax-2820 Laser Fax Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
