Question about Ricoh AC205 All-In-One Laser Printer
Ricoh ac205 scanner locked - Ricoh AC205 All-In-One Laser Printer
I NEED A DRIVER FOR RICOH AFICIO FX 200L (PRINTER/SCANNER/FAX)
Hi there!
You can download the driver for Ricoh Aficio FX200L from this website: http://support.ricoh.com/bb/html/dr_ut_e/re/model/ac205/ac205en.htm
Just choose your Operating System and it will scroll to the list of driver that is compatible with your computer.
Hope this helps!
Apr 09, 2011 | Office Equipment & Supplies
WHERE CAN I GET A DRIVER FOR MY RICOH AC205 TYPE 103 COPIER PRINTER WHICH IS COMPATIBLE WITH WINDOWS 7
Hi, Here you can download the windows seven compatible driver for your printer Ricoh AC205L.Download from the below link. http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/ac205/ac205en.htm 1)Select the Operatin System and the PCL 6 is your printer driver.You can download other utilities also. 2)Hope the given information is useful to you. 3)Feel free to post your comments to correct my mistakes if any.
THANKS FOR USING FIXYA. BEST WISHES.
Dec 05, 2010 | Ricoh AC205L All-In-One Printer
I tried to print a document from my computer and the printer says( No paper) Add paper. The tray is full. It then says PC Print Pending. Can you tell me what to do to clear this problem. I have a AC205..
Your problem may be a simple as paper dust.
Take all the covers off get a can of canned air and blow out everywhere you can reach especially in the areas where there are or my be sensors. Be careful not to spay to much in one place or you'll end up with condensation and then condensation problems.
Jun 14, 2010 | Ricoh AC205 All-In-One Laser Printer
Cant install ac205 with usb and i dont have a disk
Donload printer river here, postscript driver and printer switcher here:
http://www.ricoh-usa.com/solutions/common/universalprintdriver/default.asp
Dec 23, 2009 | Ricoh AC205 All-In-One Laser Printer
My Ricoh AC205 Printer just blinked and turned off on its own - no light on the display panel. There was power on the cord. The 2 fuses visible when I opened the back panel are not busted. Any solution to...
I see you did not get an answer on the Ricoh AC205L problem. No power.....I have 4 of these machines with the same problem. Did you find anything out? Vendors want too much money for a board replacement. The machine would be a throw away and not recomended to buy Ricoh again, unless I can find a reasonable fix. (Component replacement, etc......)
Dec 22, 2009 | Ricoh AC205L All-In-One Printer
Ricoh ac205 open heat error
You have either a broken heat lamp, or thermostat (thermal fuse).
Heat lamp PN G144 9731 and/or thermostat PN B273 7502
Aug 03, 2009 | Ricoh Office Equipment & Supplies
Faxes stuck in memory
The only reason they shouldn't print is due to a technical problem. There are no error messages or red lights at all?? That's very strange.
It must be a software glitch of some sort. You can do a memory clear to empty it out and perhaps restore the proper functioning, but it does set the machine right back to factory defaults, so you will have some settings to restore afterward.
You can get the manual here if you don't have it. Memory reset procedure is on page 8.2:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/ac205/ac205en.htm
Mar 04, 2009 | Ricoh AC205 All-In-One Laser Printer
Savin AC205
In the print output tray there is a green lever that locks the scan bed in place. Move this lever and the problem should be resolved.
Dec 26, 2008 | Ricoh AC205 All-In-One Laser Printer
Ricoh AC205 All-In-One Laser Printer Logo
187 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
