Question about DCS DD36SS 36" Downdraft Ventilation System with 600 CFM Internal Blower and Simple One Touch Operation
Dcs dd36ss problems - DCS DD36SS 36" Downdraft Ventilation System with 600 CFM Internal Blower and Simple One Touch Operation
I cleaned the sump of my DCS 36 inch cooktop with easy off as instructed but it left a black stain on the aluminum bases. I have asked DCS for some help but it's been over a month a they don'
Youre gonna hit me... Soak it with lemon juice then clean with water. And next time you gotta clean metals, use vinegar+salt or sugar + olive
oil.
Jul 05, 2012 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
DCS 36 in. CS-366 LP Cooktop ignition
in that burner something is short check it out
Dec 09, 2007 | DCS 36 in. CP-366 Gas Cooktop
DCS CT365SS igniter wires?
no not standard. but you can replace them if you know a good place to buy high temp wires. If not buy the upper wire harness for the range and the igniter wires will be in that.
Jan 06, 2012 | DCS Cooktops
DCS Cooktop CTD-365 one burner won't ignite/no spark or ticking. I cleaned ignitor.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 11, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Problems with DCS cook top ignitors...PARTS?
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
heatman101
Jun 20, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
The igniters will not stop sparking on my dcs cooktop when I turn the burners on. This happens with all burners.
Because this is happening on all burners, i would say you have a faulty ground to the ignition module.
Dec 19, 2009 | DCS 36 in. CP-366 Gas Cooktop
Where can I get a igniter for the DCS CTD-365n cooktop.
i couls not find this model / reck your model # and need the brand / this will help . sorry mm
Dec 02, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
How to remove the knobs and replace gas valve on DCS 36" gas cook top - looks like wobbley stem.
The knobs should just pull straight off. Don't tilt or bend them around, just pull them straight. off.
Nov 23, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
DCS DD36SS 36" Downdraft Ventilation System with 600 CFM Internal Blower and Simple One Touch Operation Logo
29 people viewed this question
Top DCS Cooktops Experts
Timllfixit
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
