How do i change the ink cartridges for the photosmart 7960
  • 826 Answers
Make sure the printer is ON.
2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place.
The print carriage moves to the far right side of the printer.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
4. Pull the print cartridge toward you out of its slot.
5. If you are removing the black print cartridge in order to install the photo print cartridge, store the black print cartridge in the print cartridge protector. For more information, see Use the print cartridge protector. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge. The HP Inkjet Supplies Recycling Program is available in many countries/regions, and lets you recycle used print cartridges free of charge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place.
If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.
8. Close the print-carriage access door.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Jan 15, 2013
gaya79
  • 31 Answers
SOURCE: No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Posted on Nov 06, 2007
ithana
  • 185 Answers
SOURCE: hp photosmart 7960 printer
open the printer software check the catridge level.it willl help u.
Posted on Sep 03, 2008
leroyal
  • 2120 Answers
SOURCE: HOW DO I CLEAR A PAPER JAM, IN MY HP PHOTOSMART 7960 PRINTER
Look in the rear of the machine for a large knob that releases a door.
Posted on Dec 28, 2008
DosHog
  • 168 Answers
SOURCE: Photosmart 7960 prints blank documents; prints from internet ok
If it can print from the internet, it is working properly. I would disconnect the printer from the computer, uninstall the drivers and reboot twice. Reinstall the drivers and hook up the printer when instructed. Make sure that you select this as the default printer. (unless, of course, you have another as default)
Posted on Jul 24, 2009
SOURCE: re-configuring for european ink cartridges
i had thed same problem. after hours of trying different options i finally got it to work. i have a hp 3210 that i brought from the usa to irelnad and when i put in irish cartrtidges it said " this printer is cinfigured to use 02 cartridges" Iriss cartridges are 363. so what i done was , while the printer was turned on i held down the " Black" button and the "Color" button at the same time. Keeping them held I powered off the printer , keeping them held until the printer was completely powered off. when i turned the printer back on the region had being reset and it asked me to choose my language and country. chose " Ireland". Now works!!!
Posted on Oct 15, 2009
On HP Photosmart 7960, which cartridge to replace when the blue and green look pale
The printer takes a tri-color cartridge and a black cartridge. So anytime there is an issue with color, replace the tri-color cartridge. As far as using compatible inks, you will not be able to use HP's software for ink levels with compatible inks. This feature will work only with HP ink cartridges.
Oct 23, 2011 | HP PhotoSmart 7350 InkJet Printer
To know when ink needs rep
With compatible ink you will just have to watch for colors fading. HP software supports only HP ink, so the ink monitoring software will not function with compatible cartridges
Oct 21, 2011 | HP PhotoSmart 7960 InkJet Printer
All ink cartridge levels are full yet the printer is printing everything in pink
Check and see if you removed the plasdtic tape that covers a tiny hole in the ink cartridge.
Sep 07, 2011 | HP PhotoSmart 7960 InkJet Printer
Where do i go to find out my ink levels in my hp photosmart 7960 printer???
On the printer hit:-
Menu
Tools
Print Test Page
On the left side about 2 inches down is the cartridge status
Jan 17, 2011 | HP PhotoSmart 7960 InkJet Printer
Printer keeps saying black/grey ink problem
I think Cartridge is exhausted .. or less fit the cartridge in place.
I recommend ... Cartridge is to check .. if already in place .. or not ..
if not. please pas on the location of a place .. if need to clean the cartridge .. then .. pull the power the printer .. and then .. pairs again ..
I hope you can help.
Jun 16, 2009 | HP PhotoSmart 7960 InkJet Printer
Recalibrating a refilled black ink cartridge for a photosmart 7960
your printer probably cannot recognize one of both cartridges
clean the contacts of the cartridges and the contacts of the cartridge carrier  with a wet towel
if that does nt work your ink cartridge has probably overheated  because air has left in the cartridge after refilling and must be replaced
check here the right way for refilling
http://www.youtube.com/watch?v=dhDaKSzou50
Sep 09, 2008 | HP PhotoSmart 7960 InkJet Printer
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
Make sure the cover that holds the ink cartridge in place is completely closed down on the cartridge. Also make sure there is not a pencil or something under the cover where the ink is , obstructing the print head
Jun 15, 2007 | HP PhotoSmart 7960 InkJet Printer
46 people viewed this question
k24674
jasbo
jasbo
